ENGINE SWAP
18 Dec 2008 15:56 #253428 by JIMMY7
ENGINE SWAP was created by JIMMY7
I HAVE A 77 KZ 650 THAT PUT THE #1 ROD THROUGH THE BLOCK!
MY QUESTION IS,WILL A 750 OR 900 ENGINE FIT WITHOUT MUCH TROUBLE? IF IT WILL CAN I REUSE MY EXISTING EXHAUST AND RELATED PARTS? THANKS FOR READING AND HOPE TO HEAR FROM YOU!
1977 KZ650
1974 HONDA DRAGBIKE/FZR600 ENGINE
1974 HONDA CL200 TWIN
1971 Yamaha XS650 Bobber
18 Dec 2008 15:59 #253430 by jordan
Replied by jordan on topic ENGINE SWAP
the 900 or larger motors will require a little work to make fit, but is doable and would be pretty cool. But if you want to keep it easy, a 750 motor will bolt up just right, and should be pretty easy.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
18 Dec 2008 16:01 #253432 by JIMMY7
Replied by JIMMY7 on topic ENGINE SWAP
SO I WOULD PROBABLY NEED TO MODIFY THE FRAME FOR A 900 OR LARGER HUH.
1977 KZ650
18 Dec 2008 23:30 #253495 by donthekawguy
Replied by donthekawguy on topic ENGINE SWAP
There is someone on here that has a 900 motor in the 650 frame. I think it fit but you have to take the motor out to adjust the valves. I would go with the 750 and put an 810cc kit on it.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
19 Dec 2008 04:23 #253518 by JIMMY7
WHAT IS INVOLVED IN A 810 SWAP? IS IT JUST NEW CYLINDERS OR ? DO THEY MAKE IT IN A KIT? THE BIKE IS SET UP LIKE A CAFE RACER SO THIS WOULD BE KINDA FUN.
1977 KZ650
19 Dec 2008 05:25 #253522 by donthekawguy
Try this link. It's the APE site and should have all the info you need. kzzone.com/pistons.html
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
19 Dec 2008 06:12 - 19 Dec 2008 06:13 #253533 by Bluemeanie
Replied by Bluemeanie on topic ENGINE SWAP
Here is a pic of a Z1 in a 650 frame, note clearance at top of motor and custom motor mounts at bottom. Can be done but lots of work. (click to enlarge)
Last edit: 19 Dec 2008 06:13 by Bluemeanie.
19 Dec 2008 06:27 #253537 by jordan
that looks sweet.B)
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
19 Dec 2008 08:16 #253546 by keith1
Replied by keith1 on topic ENGINE SWAP
jordan wrote:
that looks sweet.B)
sure does
19 Dec 2008 10:43 #253560 by saxjonz
Replied by saxjonz on topic ENGINE SWAP
It can be done but why?????????????????????? The motor is too much for that small little frame. Maybe a 750 but I guess if you don't spend much on it why not?
79 LTD B3
20 Dec 2008 09:28 #253676 by Beatpoet
Replied by Beatpoet on topic ENGINE SWAP
... Take the motor out to adjust the valves...
I wonder how much it would cost to modify the valve cover into a two-piece that bolts together with a nice flange?
20 Dec 2008 10:52 #253689 by wiredgeorge
Replied by wiredgeorge on topic ENGINE SWAP
The rear brake looks like a disk. What is that thing that looks like a tin can with three holes? Why not just use a 900/1000 frame and have the engine bolt right up?
