Got my e bay cams
- Buda
16 Dec 2008 22:59 #253156
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Got my e bay cams was created by Buda
Got my cams in the mail the other day. Standard J cams for my LTD is there anything I should do with them before installing? I've never used used cams in anything before.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
16 Dec 2008 23:15 #253157
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Got my e bay cams
Just make sure they are free of rust, and i would say put a light coat of oil on them prior to instilation.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Buda
17 Dec 2008 11:16 #253230
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic Got my e bay cams
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- timebomb33
- Thank you received: 10
17 Dec 2008 18:56 #253299
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Got my e bay cams
check them for pitting and galling and measure them aqgainst your stock cams to see if there is much differance. measure across the lobe and then measure across the base circle and then subtract the two figures and that will be your lift.
- PLUMMEN
- Thank you received: 104
17 Dec 2008 21:05 #253330
by PLUMMEN
Replied by PLUMMEN on topic Got my e bay cams
slop some assembly lube on the lobes and bearing journals before installing them
- timebomb33
18 Dec 2008 20:31 #253476
by timebomb33
also loctite the sprocket bolts i like to use the red stuff it seems to hold pretty good and the bolts wont back out.
- Buda
18 Dec 2008 23:37 #253499
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
thanks fellas:laugh:
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
