KZ750 twin flywheel bolt...
- MyHobbyKawasaki
15 Dec 2008 20:15 #252941
by MyHobbyKawasaki
1980 Kawasaki KZ750G LTD-2
1984 Kawasaki KE100 Dual Purpose
KZ750 twin flywheel bolt... was created by MyHobbyKawasaki
Hi,
I recently purchased a 1980 KZ750G twin in a couple of pieces, and I am working on putting it back together...
The problem is that I can't seem to find any place to get the bolt that holds on the flywheel. It is that really goofy left-hand fine-thread metric bolt.:S I tried one of the 10mm kind for the B1-B2, but it is the larger 12mm one that I need. Does anybody know where to get one of these?
Thanks in advance,
Andrew
Thanks in advance,
Andrew
- MFolks
- Thank you received: 540
15 Dec 2008 20:48 #252954
by MFolks
Replied by MFolks on topic KZ750 twin flywheel bolt...
Have you tried
www.z1enterprises.com
? Jeff seems to know most things Kawasaki.
- bountyhunter
- Thank you received: 337
15 Dec 2008 22:24 #252968
by bountyhunter
Replied by bountyhunter on topic KZ750 twin flywheel bolt...
As a last resort, you could try the OEM Kawi part drawings at Babbittsonline.com to get the Kawi part number. There's an off chance it might still be available from kawi if it's used on more than one model.
- MyHobbyKawasaki
16 Dec 2008 06:52 #253007
by MyHobbyKawasaki
Replied by MyHobbyKawasaki on topic KZ750 twin flywheel bolt...
No, I havn't tried Z1 enterprises yet. Thanks.
FYI, it is part #92001-1012 It seems Kaw isn't making it any more, as every place I have tried say it is discontinued. According to the Kaw parts diagrams, it is the same part as on the '78-'79 KZ750 twin.
Would anybody here have one laying around that you wouldn't mind selling?
Thanks again,
Andrew
Thanks again,
Andrew
- MFolks
16 Dec 2008 07:18 #253011
by MFolks
Just a thought, but have you tried
www.boltdepot.com
or any specialty fastener companies?
- MyHobbyKawasaki
06 Jan 2009 14:14 #256449
by MyHobbyKawasaki
Hi again,
Kawasaki is definitely not making any more of these, as I was just told by my local Kawasaki shop that it has been discontinued.
I am still looking for one, I guess I will have to try some junkyards and watch eBay... Can anybody here confirm these measurements? 12mm X 1.25 pitch X ??mm I might try ordering one from a bolt supply store if I know what I am looking for.
Thanks for all the suggestions and advice,
Andrew
Andrew
- mariozappa
- Thank you received: 8
07 Jan 2009 07:25 #256547
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic KZ750 twin flywheel bolt...
I ordered one from bikebandit.com...
They're called bandit for a reason.
1977 KZ650C1
- Sandy
- Fly High,Tony
- Thank you received: 13
07 Jan 2009 07:59 #256548
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic KZ750 twin flywheel bolt...
1977 KZ1000 A-1
- 76 LTD
08 Jan 2009 03:04 #256675
by 76 LTD
Replied by 76 LTD on topic KZ750 twin flywheel bolt...
I have one if i can locate it.$5 plus shipping
- MyHobbyKawasaki
09 Jan 2009 07:58 #256940
by MyHobbyKawasaki
76 LTD, That would be great! Just make sure it is the 12mm one... I don't need another 10mm, I already have one I don't need. Let me know if you find it.
Thanks for the list too, Sandy. I tried BikeBandit, they told me it was unavailable... :S Hmmm
Andrew
Andrew
- 76 LTD
10 Jan 2009 11:39 #257090
by 76 LTD
I found it but i think its a 10mm.takes 14mm wrench.i dont have a way to measure it but a 10 mm wrench fits on the shank of the bolt.it came off a 76 so evidently they changed them some time after that probably in 78 thats when Kawasaki seems to have started changing little things on most of the bikes.(sell more parts). Sorry but hey we tried.
- Thank you received: 2098
10 Jan 2009 11:53 - 10 Jan 2009 11:55 #257092
by Patton
Replied by Patton on topic KZ750 twin flywheel bolt...
Last edit: 10 Jan 2009 11:55 by Patton.
