Exhaust backfire?
- OldHippie
Exhaust backfire?
15 Dec 2008 14:41
First off...Thanks for all the input as to my clutch cable adjustment problem. I got it fixed..seems that when I put the cover back on the clutch release mech. wasn't seated correctly.
Now on to bigger and better things. The bike was always hard to start ever since I got it (2 months ago). Now not only does it NOT start, it backfires (sounds like a shot gun going off)
I've had the battery on a trickle charge, so I know that's not the problem with starting and yes the fuel is turned on and yes I put in new plugs. Any ideas?
As far as the backfiring... I had the carbs off once already,they looked clean, maybe the jets need attention or could it be the carbs aren't in synch?
There is power in words...just don't put too many together.
my ride: KZ1000P19
my ride: KZ1000P19
- Kawickrice
Re: Exhaust backfire?
15 Dec 2008 14:44
Are you running points? It could be ignition rather than carburation.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
15 Dec 2008 15:32
The reason I ask is I installed dyna coils with wiredgeorge mod but kept running points. After 3 months it was hard to start and would backfire loud like you describe. I traced it to my condensers, the power from the coils was to much I guess. I installed a dyna ignition and problem solved. Starts every time now. If you can turn off your headlight while cranking you will get more juice to ignition and maybe she will start so you can diagnose the problem. Good luck as it is probably something simple hopefully.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
15 Dec 2008 17:44 - 15 Dec 2008 18:04
OldHippie wrote:
If ignition has a mechanical advancer, would check it to assure not being stuck in the advanced position.
Could do static timing check to assure correct F mark alignment.
Would also perform compression test (or better yet, a leakdown test) to help determine whether an intake valve is leaking. First "dry" compression test, then "wet" (teaspoon of oil put inside through sparkplug hole) compression test. Remember to hold throttle wide open during compression testing.
Comparing psi figures between dry and wet compression tests often helps determine whether a valve is leaking, and extent of blow-by past piston/rings. The leakdown test identifies which valve (intake or exhaust, or both), and amount of blow-by past pistons/rings into crankcase.
Then check all valve clearances and adjust to specs if needed.
Good Luck!
... does it NOT start, it backfires....
Good Luck!
Last edit: 15 Dec 2008 18:04 by Patton.
- OldHippie
15 Dec 2008 22:25
Hey thanks I didn't think and the advance.
Have look into getting the kit for compression tests, got the manual for the bike so I should be able to do the static timimg bit.
my ride: KZ1000P19
my ride: KZ1000P19
- nads.com
15 Dec 2008 23:32
anytime i start a bike and it backfires at idle i go after the idle circuit in the carbs, looking for blockage and a lean mixture. sometimes points will arc when closed, might want to clean them and look for pits and burns. when condensers go out they burn on the points contacts. If the mix. screws make no change in rpm when turned in and out and the lean backfire is present suspect the idle circuit passage blocked on one or more carbs. any vac. leak at the boots can cause backfires. A fouled spark plug firing on alternate strokes can ignite fuel in the pipes. check for dry plug or plugs when diagnosing carburation.
