what order does the oil filter and cup go on a 550
- cott10r
- Motorcyclist for life!!!
13 Dec 2008 15:40 #252420
by cott10r
2012 kawasaki concours 14
2014 suzuki gsxr 1000
2014 honda crf 250L
1983 kawasaki gpz 550
what order does the oil filter and cup go on a 550 was created by cott10r
HELP!!! im in the middle of an oil change on my 1982 550 ltd as we speak and i just pulled the oil filter out, in every other kawi i have ever owned there is a spring, a washer, then the filter than the metal can thingy goes on top over the filter:S . i pulled this one out and there is no spring, no washer and the oil filter is sitting in the cap, is this right? or is the metal cap on wrong and parts missing (spring & washer) please help its getting dark
2014 honda crf 250L
- RonKZ650
- Thank you received: 240
13 Dec 2008 17:01 #252439
by RonKZ650
Replied by RonKZ650 on topic what order does the oil filter and cup go on a 550
It should be same as a KZ650 and that is the cup sits at the bottom, then the spring, then the washer, then the filter. That's the correct orientation, but contrary to stuff you may read, where the filter sits on the bolt is really not all important. If the spring and/or washer is missing it won't effect the filter's function. I think the spring/washer are mainly there just to hold the filter snug against the pan so it doesn't shake itself apart. Snug against the pan or not doesn't effect function. Oil goes through the holes in the bolt and into the filter and out regardless.
- arai59
- Banned
- Thank you received: 1
13 Dec 2008 17:11 #252441
by arai59
Replied by arai59 on topic what order does the oil filter and cup go on a 550
I always put things back together the way they came off.:silly:
- H2RICK
- Is this a fun bike, or what!!!
13 Dec 2008 19:50 #252458
by H2RICK
All correct except for the above statement.
Oil flows from the pump into the OUTSIDE area of the filter, then through the filter media and THEN through the centre mounting bolt and out into the pressure side of the supply system. Filters that have a metal centre core (like the 650 and many others) are meant to have the flow from outside to inside with the media being supported by the core. This is necessary because there is always a pressure differential across the filter media with the higher pressure on the outside and the lower pressure on the inside on the 650 and, I presume, the 550.
If the flow was the other way, the filter would have a perforated metal cover on the OUTSIDE to retain the media against the higher pressure from the centre bolt/inside.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic what order does the oil filter and cup go on a
- cott10r
13 Dec 2008 20:37 #252468
by cott10r
2014 honda crf 250L
Replied by cott10r on topic what order does the oil filter and cup go on a 550
i went ahead and put it back together the way i found it, it is missing the spring and washer though. i did notice that the metal cap is shaped different than the caps that sit atop the filter, this one has a flat bottom compared to the indented bottom that the top mounted caps have, i hope this is right, i dont want this thing blowing up, its soooo much fun to ride!!!
2014 honda crf 250L
- Bluemeanie
- Thank you received: 14
14 Dec 2008 04:49 - 14 Dec 2008 04:51 #252508
by Bluemeanie
Replied by Bluemeanie on topic what order does the oil filter and cup go on a 550
Yes, the filter is missing the washer and spring. Your bikes filter setup (below) is the same as a 650. No harm will come running as is but would bug me enough to locate a spring and washer. (click pic to enlarge)
Last edit: 14 Dec 2008 04:51 by Bluemeanie.
- cott10r
14 Dec 2008 06:23 #252516
by cott10r
2014 honda crf 250L
Bluemeanie wrote:
ya i'm gong to locate a spring and washer because it WILL bother me, im very paticular about things being right, thank you guys very much for your prompt help
2014 honda crf 250L
