1015 block to 900 cases
- BARNEYHYPHEN
20 Feb 2006 19:51
I'm going to be transplanting a 1015 block onto 1976 900 cases. I'm told I will likely have to have the cases machined to accept the 1015 block.
Could someone please tell me what clearance I need to achive between the sleeves and the cases. Thanks.
- wireman
Re: 1015 block to 900 cases
20 Feb 2006 20:03
just enough to get the cylinder on there dont take off too much,cases help support the sleeves.
goodluck,happy wrenching!
- solomrus
20 Feb 2006 20:19
i was told that a 1015 block on 900 cases was a drop in.
the PO of my street engine did that. pretty fun little setup. revs nice, has lots of tq.
--r
--r
198o kz1ooo Bravo Four
- wireman
20 Feb 2006 20:32
your recruiter has told you a lie son!:whistle:you can do it with a die grinder if youre carefull,youll have to split the cases first.goodluck,happy wrenching!
Post edited by: wireman, at: 2006/02/21 00:26
- wireman
20 Feb 2006 22:36
drop the 1000 cylinder down over the studs and scribe around bottem of sleeves ,pull cylinder back off this is howmuch you need to remove put a little bit of a bevel on the edge of the cases to make it easier to install and avoid stress risers.goodluck,happy wrenching!
- wiredgeorge
21 Feb 2006 05:32
I have installed a 1015 block on a 903 case several times in the past year and have had to clean up the cases with a die grinder each time. It can be done it about 5-10 minutes so not much material needs to be removed. You will have clean up the material towards the front of the case where the liners will be hitting just a bit. Test fit the block and remove some material and then test fit again until the block slides easily onto the two engine dowels. Once you are done, I suggest you split the cases and clean the mess out good before final assembly so it is best to do this step BEFORE fitting that new cam chain.
- solomrus
21 Feb 2006 07:45
thanks for the details guys.
now i know for sure.
--r
--r
- BARNEYHYPHEN
21 Feb 2006 08:42
Thanks for all the great advice. Might even give it a shot this weekend.
- wireman
21 Feb 2006 09:44
dont thank me were all in this together,im pullen for ya .keep your stick on the ice!(RED GREEN)
- teddycp
15 Mar 2006 11:54
WG, you stated "I have installed a 1015 block on a 903 case several times in the past year and have had to clean up the cases with a die grinder each time." Does this apply to all years of 1015 blocks or just later years? Anyone else with info, please feel free to chime in here!!!!!!
- wiredgeorge
15 Mar 2006 12:51
The 77/78 cases are SLIGHTLY different than the 79/80 cases in that there are slots around the bases of the liners where you install those thin orings. The liners from both the early and later 1015cc blocks will sometimes hit the front of the upper case. I do know that some folks have been able to drop 1015cc blocks on with no clearancing but I have not been able to do it. I have installed four 1015cc blocks on 903cc bottom ends in the past year and all have had to be ground a bit; some a bit more than others. It is best to split the cases when doing the grinding as it makes a darn mess inside the cases. You probably should swap out cam chains anyway at this time.
- teddycp
16 Mar 2006 10:08
OK WG, I got that part alright, but have you had any experience installing a 1015 to a 73-75 Z1 case? I have a 75 and would like to do that if it's not too difficult. Thanks....Teddycp
Post edited by: teddycp, at: 2006/03/16 13:09
