Piston rings for kz650 (standard size) ?
- HenryKrinkle
Thanks all...
- bountyhunter
- Thank you received: 337
I would try babbittsonline.com and see if Kawi still sells them. If they do, babbitts will sell them about 40% under dealer price.
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
1980 KZ500 B2
- MFolks
- Thank you received: 540
- bountyhunter
Problem is, Babbitts lists all the old Kawi OEM parts, and you can order them, and then they try to get them from Kawi and you find out they are discontinued when they cancel the order.$47.94 per set at babbits.standard,first and second.
Just did that last week for new carburetor slides.
- HenryKrinkle
Man, those buggers are pricey!
I only had a problem with one cylinder and the others were consistent with each other and in spec for compression. I also just got a set of four used pistons with rings. I would assume that at least one of those ring sets is okay.
Is there any way to measure the rings to check if they are okay?
My cylinders are being honed and the block flattened at the machine shop right now. Would it advisable to use my old rings that were ok and a set of the new (used) rings on the bad cylinder? Or should I not sell myself short now that I've gone this far? Budget is getting real tight...
Thanks
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
The vertical clearance between the ring and piston groove is a critical spec, the manula for the engine will spec it. You actually get more compression loss through that path than blowing by the ring/cylinder wall interface in old pistons.Is there any way to measure the rings to check if they are okay?
On mine the spec is .05 mm new, 0.15 mm maximum wear limit.
The other check is to put the ring in the cylinder and then measure the end gap of the ring, that will tell you about cylinder and ring wear.
- bountyhunter
Sure it's a ring and not a leaky valve? I had 77k miles on my 750 and the rings were still holding up pretty well, but the valves had to be done twice in that interval.I only had a problem with one cylinder and the others were consistent with each other and in spec for compression.
- HenryKrinkle
yet the compression went from 125 to 150+ when I did a wet comp test..
- steell
Not positive,
Save your money and check the valve clearances.
Generally, if it's bad rings then it affects all cylinders near equally, and if it's bad rings then adding oil will generally up the compression to over 180 psi.
The last motor I did a wet check on was a 750 four, 70-80 psi dry in all cylinders, added oil and compression shot up to near 200 psi.
