Piston rings for kz650 (standard size) ?
  • HenryKrinkle
  • Topic Author
11 Dec 2008 21:57 #252142 by HenryKrinkle
Piston rings for kz650 (standard size) ? was created by HenryKrinkle
I need 4 sets of rings for my z650 and cannot find them anywhere! The only ones I could find are 2 over @ 0.40. Do any other bikes use the same rings? Where can I find these guys???
Thanks all...
11 Dec 2008 22:20 #252144 by bountyhunter
Replied by bountyhunter on topic Piston rings for kz650 (standard size) ?
I have seen them rarely on fleabay. I know where to get new sets for the 750 twin and 400 twins, but not the fours.
I would try babbittsonline.com and see if Kawi still sells them. If they do, babbitts will sell them about 40% under dealer price.
12 Dec 2008 01:50 #252155 by 77_650B1
Replied by 77_650B1 on topic Piston rings for kz650 (standard size) ?
eBay's about the only spot. Its gonna be really hard to find them. I've heard of sets costing guys upwards of $200 though, it sucks.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
12 Dec 2008 15:14 #252248 by SPARKY47
Replied by SPARKY47 on topic Piston rings for kz650 (standard size) ?
$47.94 per set at babbits.standard,first and second.
1980 KZ500 B2
12 Dec 2008 15:24 #252251 by MFolks
Replied by MFolks on topic Piston rings for kz650 (standard size) ?
Have you tried www.vintagecyclepsrt.com ?
12 Dec 2008 22:14 #252306 by bountyhunter
Problem is, Babbitts lists all the old Kawi OEM parts, and you can order them, and then they try to get them from Kawi and you find out they are discontinued when they cancel the order.
Just did that last week for new carburetor slides.
  • HenryKrinkle
  • Topic Author
12 Dec 2008 22:17 #252308 by HenryKrinkle
Replied by HenryKrinkle on topic Piston rings for kz650 (standard size) ?
Thanks guys...
Man, those buggers are pricey!
I only had a problem with one cylinder and the others were consistent with each other and in spec for compression. I also just got a set of four used pistons with rings. I would assume that at least one of those ring sets is okay.
Is there any way to measure the rings to check if they are okay?
My cylinders are being honed and the block flattened at the machine shop right now. Would it advisable to use my old rings that were ok and a set of the new (used) rings on the bad cylinder? Or should I not sell myself short now that I've gone this far? Budget is getting real tight...
Thanks
  • Mcdroid
  • Away
  • Gone Kwackers
13 Dec 2008 01:43 #252318 by Mcdroid
Replied by Mcdroid on topic Piston rings for kz650 (standard size) ?
Get upon www.kawasaki.com and check for your rings...they show the rings as still being available...and if you go that route, check with www.Z1enterprises.com as I strongly suspect Jeff can beat Babbitt's prices:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
13 Dec 2008 18:16 - 13 Dec 2008 18:19 #252450 by bountyhunter
The vertical clearance between the ring and piston groove is a critical spec, the manula for the engine will spec it. You actually get more compression loss through that path than blowing by the ring/cylinder wall interface in old pistons.
On mine the spec is .05 mm new, 0.15 mm maximum wear limit.
The other check is to put the ring in the cylinder and then measure the end gap of the ring, that will tell you about cylinder and ring wear.
Last edit: 13 Dec 2008 18:19 by bountyhunter.
13 Dec 2008 18:22 #252451 by bountyhunter
Sure it's a ring and not a leaky valve? I had 77k miles on my 750 and the rings were still holding up pretty well, but the valves had to be done twice in that interval.
  • HenryKrinkle
  • Topic Author
13 Dec 2008 23:20 #252499 by HenryKrinkle
Not positive,
yet the compression went from 125 to 150+ when I did a wet comp test..
14 Dec 2008 06:12 #252513 by steell
Replied by steell on topic Piston rings for kz650 (standard size) ?
HenryKrinkle wrote:
Not positive,
Save your money and check the valve clearances.
Generally, if it's bad rings then it affects all cylinders near equally, and if it's bad rings then adding oil will generally up the compression to over 180 psi.
The last motor I did a wet check on was a 750 four, 70-80 psi dry in all cylinders, added oil and compression shot up to near 200 psi.
