KZ650 Cam Timing Instructions and Question
- boojr
11 Dec 2008 16:13 #252054
by boojr
74 XL250
78 KZ400B1
79 KZ650SR
84 V65 Sabre
06 VMAX
KZ650 Cam Timing Instructions and Question was created by boojr
Have a 1979 KZ650 SR. Just purchased it and not sure on history. Ran faily well, drove it 2 miles home.
Nonetheless, am doing a tune-up.
Adjusted valve clearance by marking cam chain and removing tension wheel, and doing one cam at a time.
Maintained tension on cam chain while working. However, was looking at cams and wanted to check cam timing to be sure.
Anyhow, i think there may be a little problem.
When I set the 1,4 T to the tick mark, the cam arrows are not lined up with the cylinder head. The intake is pointing slightly upward, and exhaust is slighlty down.
When I move to the 1,4 F mark, the arrows are match up pretty well with the clinder head.
Is this out of time?
If so, how do you check timing properly? The only marks on the cams are 2 arrows and a slanted line on each with EX next to them.
Also, how are the arrows to align with cylinder head? Are the uppose to be directly parallel with the crankcase? Meaning, if you slide a straight-edge along the case where the gasket sets, it should strike the arrow on the camshaft and be directly parallel to it?
Maybe I knocked it off a tooth while pulling the cams. Removed one at a time and held tension on the chain. Just need to be sure it lines up properly.
Dealer told me to look for an upside ZX.. on the exhaust cam, don't seet it. Working from right side of bike. All i see is 2 pointing arrows on each cam and a slashed like with an ex on both cams.
Any help would be appreciated.
74 XL250
78 KZ400B1
79 KZ650SR
84 V65 Sabre
06 VMAX
- anarki650
- Thank you received: 5
11 Dec 2008 16:35 #252057
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic KZ650 Cam Timing Instructions and Question
09 Kawasaki ER6n
Omaha NE
- anarki650
11 Dec 2008 16:36 #252058
by anarki650
09 Kawasaki ER6n
Omaha NE
If you want me to email you the full sized pics so you can read them better just shoot me an email, axton_kahler@yahoo.com.
09 Kawasaki ER6n
Omaha NE
- Mark Wing
- Thank you received: 22
11 Dec 2008 21:24 #252137
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic KZ650 Cam Timing Instructions and Question
I think it skipped a tooth. With the T lined up the arrow should be pointing at the top of the cylinders. I've had my head off several times and I'm sure it skipped a tooth.
Yorba Linda Cal.
