Vance and Hines exhaust future
Re: Vance and Hines exhaust future
12 Dec 2008 05:33 - 12 Dec 2008 05:34
#252170
EricHa wrote:
... If you're going to lower your bike very much, you have to at least consider a sidewinder/pro pipe.
On the Z1 with the Yoshi pipes, lowering the front end by raising the fork tubes an inch higher in the clamps did not create much of a clearance issue, either ground or wheel/fender with hard front braking.
Good Luck! :)
Last edit: 12 Dec 2008 05:34 by Patton.
  • wiredgeorge
  • wiredgeorge's Avatar
12 Dec 2008 06:54
#252179
Jeff, IF you have pipes made, keep in mind that MANY owners originally had 4 into 2 pipes. The only sources for 4 into 2 have turn out mufflers which I doubt most folks enjoy looking at. I sure don't. If you get pipes made, a 4 into 2 with megaphone mufflers would really be nice... similar to the OEM stuff on the later KZ1000s in chrome but I bet BLACK would also be a good seller. If you had pipes made up, I bet a 4 into 4 replica pipe would also sell if you could get the price within reason.
  • TexasKZ
  • TexasKZ's Avatar
13 Dec 2008 07:07
#252336
This place has some interesting possibilites -
www.klasmo-bikes.de/land.php?auswahl=mod...land1=USA&kunden_id=
I am particularly interested in the Cobra Duplex #710709Z, though I wonder how much shipping will be. They sell several systems that I think are not available in the US by other means, which would give them, imo, extra bling points for exclusivity.
By the way, whoever did ther English translation needs further study, so be warned - you will have to use some creative interp. of your own.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
13 Dec 2008 07:11
#252337
The 4-2 pipes would be a strong consideration.
There are some 4-2 pipes avaialble today, but they are either very expense (like the ZeCross system we sell), or too crappy (like MAC).
The key challenge is getting them made at a price point we all can live with. Most of the manufacturers require runs of 50 or more pipes at a time.
  • Jeff.Saunders
  • Vendor
  • Vendor
13 Dec 2008 07:19
#252340
The problem with importing pipes from overseas is you can run into issues with US Customs and DOT requirements. If you import a pipe for a bike later than 1977, the pipes MUST adhere to DOT/EPA standards. If US Customs determines a pipe does not conform, it may get sent back or destroyed. Because of this issue, we've avoided importing a couple of the pipes from Japan.
  • Mcdroid
  • Mcdroid's Avatar Topic Author
  • Gone Kwackers
13 Dec 2008 07:40
#252343
So, in theory, if you import a pipe for a Z1B and it not so coincidently also fits 1977-80 KZ1000B models, the pipe might slip by US Customs?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • trianglelaguna
  • trianglelaguna's Avatar
13 Dec 2008 07:40
#252344
just tell em they help motorcycles here get down to 11 miles to the gallon and the u.s will import em for us..in fact they will give us employee discount programsJeff.Saunders wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Jeff.Saunders
  • Vendor
  • Vendor
13 Dec 2008 09:02 - 13 Dec 2008 09:03
#252361
If the pipe is imported as for a Z1, KZ900 or 1977 KZ1000, you'd be OK. Import it for a 1973-1980 Kawasaki 900/1000 and you won't be.
With any import, your shipper should be including a manifest with all this information on. With individuals importing today, US Customs doesn't force you file detailed import documentation unless you go over $2,000 value - although a number of shipping companies do require a detailed contents description regardless. However, the package may still be inspected and subjected to US Customs import laws.
Historically, packages through the Post Office have not required so much detail - however, many of the laws today around the Postal Services import/export processes will be changing to level the playing field for all shipping entities regardless of whether they are government based or privately owned.
Last edit: 13 Dec 2008 09:03 by Jeff.Saunders.
  • TexasKZ
  • TexasKZ's Avatar
13 Dec 2008 16:26
#252428
Thanks Jeff,
Since I have a 1980 vintage bike, I guess I'll just forget that idea and start collecting some pvc or old clay drain pipes that will keep the EPA/DOT Nazis happy.
:S
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
14 Dec 2008 07:49
#252532
TexasKZ wrote:
Thanks Jeff,
:S
Unless something from an older bike fits. ;)
Build Thread
  • GregZ
  • GregZ's Avatar
14 Dec 2008 09:55
#252548
I would not pick a new V&H out of a ditch .Junk
Vintage Yoshi is the only option
  • PLUMMEN
  • PLUMMEN's Avatar
14 Dec 2008 10:14 - 28 Dec 2008 17:08
#252549
B)
Last edit: 28 Dec 2008 17:08 by PLUMMEN.
