valve clearance
- Indymick
09 Dec 2008 08:09 #251606
by Indymick
1979 KZ650-c3
valve clearance was created by Indymick
Checking valve clearance found #4 exhaust just a smig out about .0005 all the rest were in. Should I mess with one now or wait? 1979 zk650 c3 10,600 miles
1979 KZ650-c3
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
09 Dec 2008 08:59 #251616
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic valve clearance
A noisey valve is a happy valve. I'd adjust it to give it a little more gap, or rotate the engine by hand and recheck the clearance.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
09 Dec 2008 09:16 #251620
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic valve clearance
Indymick:
Is it too tight....or too loose ???
If it's too tight then it's not going to get better, soooo...best get it shimmed properly now rather than later.
If it's too loose, no biggy....unless it's at the top end of the allowable clearances. In that case, it will need shimming.
- Indymick
09 Dec 2008 09:40 #251621
by Indymick
1979 KZ650-c3
Replied by Indymick on topic valve clearance
the range is from .08mm to .18mm it is probly .182mm just barely out on that side the others are all close to .15mm I would need the next bigger shim to put it back in range.
1979 KZ650-c3
- timebomb33
- Thank you received: 10
09 Dec 2008 13:04 #251636
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic valve clearance
i own a lot of feeler gauges and ive never seen one yet that was accurate to the .ooo5" i'd give it a good hard run and recheck it again. or roll it around a few times and see if it changes it's not tight enough to worry about.
- bountyhunter
- Thank you received: 337
09 Dec 2008 15:42 #251645
by bountyhunter
Replied by bountyhunter on topic valve clearance
Indymick wrote:
No worries, dude....
- H2RICK
09 Dec 2008 18:39 #251674
by H2RICK
If it's not a modified engine and/or you're not racing it then I wouldn't worry about that small a difference outside the range. It'll just be noisier than it should....and if you can live with that then everything's okay.
