- Thank you received: 2
How do you degree in cams?
- RomSpaceKnight
20 Feb 2006 14:47 #25153
by RomSpaceKnight
How do you degree in cams? was created by RomSpaceKnight
Need links and tips, if not whole procedure. Thanks.
- elseed
20 Feb 2006 15:49 #25165
by elseed
'75 Z1B with mods
Replied by elseed on topic How do you degree in cams?
When I came to this point, I followed the Oldkawman's advice and bought a degree wheel and
Advice: Take it slow, step-by-step.
There's room to screw things up here, IMHO, unless you're a dang mechanical natural. Personally, I had some trouble with the positive stops you use to identify TDC -- ones I had were interfering with my valves (my intakes are oversize). Was headed for a bent valve due to this, but figured it out in time.
Do you have the tools? One tip the Oldkawman passes on: if you buy a whole "cam degree kit", you will typically get ripped off on a Harbor-Freight-type dial indicator and magnetic base. You can get those separately far cheaper. I fabbed a little steel piece to bolt to the head (using cam cover holes) as a place where the magnetic base can sit. This seems to be required for most cams.
Post edited by: elseed, at: 2006/02/20 18:53
accompanying how-to video tape
'75 Z1B with mods
- steell
20 Feb 2006 17:27 #25183
by steell
Replied by steell on topic How do you degree in cams?
Did someone mention links? :evil:
www.starracing.com/Cam%20Lobe%20Center%20Explained.htm
www.webcamshafts.com/degreeing.html
www.ducatitech.com/2v/maint/rebuild/headwork.html
www.bikernet.com/garage/cam.asp
www.ninja500.com/archives/html/EX500//2001-04/msg01017.html
Only the last one is Kawasaki (EX500) but it's basically the same for all.
This one shows you how to make your own piston stop.
inline4.motorrijden.nl/default.htm?engine/camdeg.htm&2
Post edited by: steell, at: 2006/02/20 20:30
