- Thank you received: 235
sitting 9 years engine oxidised covers???
- trianglelaguna
It really looks like this motor was smooth and (low miles???)and clean before being left,, becuase of the lack of scratches and pefect surfaces i'm finding...the problem is polishing the nooks and crannies..
I was wondering if there are any products that work like the old tarnex commercials,somthing that i can dip or brush on to conteract the ox.
This man had chromed alot of stuff too,and if i'm not careful i'm ending up with faint swirl marks from my rags that need to be rubbed out ALOT...
peace craig.
I had thought originaly about plugging all the holes and having it sand/bead blasted..but it is soooo smooth underneath it all now,not wanting to screw up and all
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- MFolks
- Thank you received: 540
- PLUMMEN
- Thank you received: 104
- Alabaster
- Dallas, TX
'07 Ducati SC1000S
'79 KZ1000
- steell
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- PLUMMEN
- steell
'Hard chrome' is not really harder than other chrome plating, it is called hard chromium because it is thick enough that a hardness measurement can be performed on it, whereas decorative chrome plating is only millionths of an inch thick and will break like an eggshell if a hardness test is conducted, so its hardness can't really be measured directly.
www.finishing.com/faqs/chrome.html
- kzr750r1
- Thank you received: 9
Nerve racking to pull and replace the seal but possible.What about the oil level glass hole? Mine looks like it has a little oil stuck behind it. Can it be removed and cleaned?
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
