Little Known Fact.....
  • H2RICK
  • H2RICK's Avatar Topic Author
  • Is this a fun bike, or what!!!
02 Dec 2008 12:25 - 02 Dec 2008 12:34
#250401
at least to a 650 newbie like me.;) :cheer:
I just acquired an early 650D1 motor for practicing things like valve clearance checking and cam removal/installation/indexing/timing. I've never owned a shimmed-valve type engine before so this is all new to me...
and I wouldn't want to bend any valves in my C2 when I'm doing the work for real, would I!!!:ohmy:
Annnyyyywayyy, while messing around with the D1 engine I went to drain the oil and found out that the sump drain plug is wayyyyy over on the left side of the engine rather than in the middle of the sump like the C (and I assume the B as well) engines have. Something to do with the exhaust arrangement and/or frame rail placement, no doubt.
I believe/believe that you'd have to change sumps if you were swapping a D engine into a B/C frame with STOCK exhausts....and vice-versa.
Can anyone verify/enlighten me on this whole thing ?? Or am I all wet here???:silly:
Edit: Hmmmm....Kawasaki.com shows the same part number for the sump casting on both the C2 and the D1. Is my memory of the drain plug location on my C2 for shite??? She's all put away in the garden shed for the winter with a nice glacier forming in front of the door so I can't get in to take a look.:angry:
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Last edit: 02 Dec 2008 12:34 by H2RICK. Reason: addl info
  • RonKZ650
  • RonKZ650's Avatar
Re: Little Known Fact.....
02 Dec 2008 15:57
#250419
Yea I think you are mistaken :) They are the same.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
02 Dec 2008 16:44
#250430
I just had to go look at my C2, even though I just drained the oil about 2 weeks ago, and have had her since the '80s.
The drain is "wayyyyy over on the left side of the engine".
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • H2RICK
03 Dec 2008 18:51
#250557
Thank you, gents. Now I'll go into the basement and give my memory a "tuneup" with the rubber hammer.....;)
Maybe I can shake it back into shape.....or not ??:laugh:
