- Thank you received: 2
head install question
- keith1
01 Dec 2008 17:20 #250241
by keith1
head install question was created by keith1
has anyone had an issue using stock style replacement nuts
with ape hd studs?....i am going to crank em down in three
stages..10 ft/lbs,20, and then finally 30...can they handle it(10.5 to 1) or should i spring for the ape heavy duty nuts and take out the doubt factor?...i guess i could always sell the new
stock ones i bought if i had to go with the ape nuts..experiences or opinions?...as always, thanks in advance....keith
- kzdev1360
01 Dec 2008 19:58 #250263
by kzdev1360
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
Replied by kzdev1360 on topic head install question
I had stock studs and nuts on my 10.25:1 720 motor on my 650 with no problems.
2006 Gsxr 1000
1976 Kz900 LTD
- timebomb33
- Thank you received: 10
01 Dec 2008 21:41 #250292
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic head install question
you might run in to a height problem with the stock nuts going on the ape studs if i remember right. the ape studs are taller than the stockers.
- PLUMMEN
- Thank you received: 104
01 Dec 2008 22:08 #250303
by PLUMMEN
Replied by PLUMMEN on topic head install question
when i pulled the topend apart on my 1327 it had stock nuts with aftermarket studs.ive run a lot higher numbers with stock parts without issues
- Tony
- Thank you received: 13
03 Dec 2008 00:28 #250465
by Tony
Replied by Tony on topic head install question
When I changed mine this summer to ape stud I measured each stud before I removed them. I put the new ape studs in and they were all pretty much the same as the old ones. I used the old nuts and torqued them to what ape recommended. I put on around 700 miles or so and re-torqued the head probably half a dozen times before the torque on the nut stopped changing.
You can check it out here.
- gane
03 Dec 2008 20:09 #250573
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic head install question
Just a thought, But, around "77'78, KZ400's had head gasket issues. It turned out that cyl studs were long enough that their acorn nuts bottomed on studs before head was properly tight. hundreds of new units rec'd new top-end kits before prob was found.G
- APE Jay
- Banned
- Thank you received: 58
03 Dec 2008 23:49 - 03 Dec 2008 23:50 #250619
by APE Jay
Replied by APE Jay on topic head install question
Our studs are the same length as stock. Where you run the risk of bottoming out the oem nits, is on motors that have had the head milled a bunch.
Our nuts are tall enough that there is no chance of this happening. Also, the stock nuts are very soft and can pull the threads when torquing much over oem specs.
If you look at photos of built KZs, you will notice that they almost all have black nuts.
Last edit: 03 Dec 2008 23:50 by APE Jay.
- PLUMMEN
04 Dec 2008 04:28 #250638
by PLUMMEN
