'84 GPz1100A2 O-rings
- droptail
30 Nov 2008 21:01
I am confused as to whether or not my application gets the (4) o-rings on the (4) corner cylinder studs at the upper case locations.
Also, I think I figured out why one of the inner head stud nuts are leaking oil. I used the OE large cam chain o-ring under a one piece (wiseco 1168) head gasket. Can't do that can you?
I am resuming this project I started 10 yrs ago. Rebuilt the engine but never fired it up (think I had the cams mixed up).
'84 GPz1100A2
'83 GS1100ES
'79 CBX1000
'83 GS1100ES
'79 CBX1000
- Mcdroid
- Gone Kwackers
Re: '84 GPz1100A2 O-rings
01 Dec 2008 00:24
droptail wrote:
Your bike does not use those...the 1982 GPz1100 was the last GPz1100 to use those.
The cams (IN and EX) are identical in your bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- droptail
01 Dec 2008 14:36
Thats what I was banking on when I put the engine together last.
Now, my problem at hand is a leaking head bolt, not one of the corner ones. I used the large cam chain o-ring under a 1-piece head gasket. Could this cause it to leak oil? Am I supposed to not use the o-ring with a 1-piece?
Thanks,
James
Thanks,
James
'84 GPz1100A2
'83 GS1100ES
'79 CBX1000
'83 GS1100ES
'79 CBX1000
- Mcdroid
- Gone Kwackers
02 Dec 2008 01:57
Yeah...you'll need the o-ring, or at least fill the groove with RTV...I think that one of the other members ought to answer this, particularly since you have punched the bike...I know there are issues with switching styles of gaskets after enlarging the bore.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- droptail
02 Dec 2008 08:51
I would like to hear from someone who has leaked oil or had referenced issues when not using the cam chain o-ring seal and a 1-piece head gasket.
I did talk with wiseco yesterday who said the 0-ring should be omitted when using their (1-piece) kit gasket. No mention of filling the groove with si.
Thanks,
James
Thanks,
James
'84 GPz1100A2
'83 GS1100ES
'79 CBX1000
'83 GS1100ES
'79 CBX1000
