welding a crank
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- PLUMMEN
- Thank you received: 104
- APE Jay
- Banned
- Thank you received: 58
tig welding is the most common
And make sure it is not twisted before welding
- wiredgeorge
metalworking.mscdirect.com/CGI/NNSRIT?PMPXNO=1749117
- Thank you received: 2098
To make sure a crank is straight, buy a 17mm drill blank. The 17mm drill blank will just fit through the hole in the rod where the pin would go. If you can put the rod through all four rod holes, it is straight. Some folks refer to this as indexing. Drill blanks can be purchased through tool stores I believe. I have had mine for quite awhile. This is something like you will need except is a yard long:
Am vaguely recalling that some particular welding rod could also be used for this purpose.
Edit -- Nope, memory failure.
- PLUMMEN
- APE Jay
- Banned
If the motor is still together, you can also check it. Using your genuine APE TDC tool and degree wheel, find TDC on cylinder #1, then move the TDC tool to cylinder #4, TDC should be exactly the same, if not, it is out of index.
Jay
- Exitpupil
- keith1
Great tips, thanks guys. I once had a forged steel sawmill blade welded by a fellow and if I recall he used a special high nickle rod with a dc stick welder. I thought maybe something like that was used? I guess I does not take much to greatly increase the twist resistance.
just my useless .02, but you could probably weld a crank with a stick welder using 6011 or 6013 rod...
its been years,(like 25) since i laid down a bead,
but if i remember that was a pretty thin rod and you wouldnt need a shit load of heat (juice) ...then again warping probably would nt be an issue....
- timebomb33
I THINK MY POWERBAND BROKE
- PLUMMEN
- timebomb33
