standard J cams
- Buda
29 Nov 2008 18:54 #249979
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
standard J cams was created by Buda
Is there any way to tell the standard j cams from the LTD or CSR cams? I bought the cams on e bay and just want to be sure.
Thanks
Tom:unsure:
Thanks
Tom:unsure:
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- keith1
- Thank you received: 2
29 Nov 2008 21:01 #249993
by keith1
Replied by keith1 on topic standard J cams
did you score the andrews x1 cams?
- steell
30 Nov 2008 04:25 #250010
by steell
Replied by steell on topic standard J cams
J, K, and M, cams can be identified by the lines next to the cam gear. Details are in the manual.
If the exhaust cam has a tach drive, then it's a CSR, the LTD and J have electronic tachs.
- Buda
30 Nov 2008 22:19 #250131
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic standard J cams
keith1 wrote:
No I got standard j cams at least i hope that's what they are.did you score the andrews x1 cams?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
30 Nov 2008 22:32 #250134
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
steell wrote:
Tom
Thanks Steel I found it in the manual. I'll find out when I get them.J, K, and M, cams can be identified by the lines next to the cam gear. Details are in the manual.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
