clutch won't disengage
  • jimmybon
  • jimmybon's Avatar Topic Author
29 Nov 2008 16:08
#249957
After sitting for 3 or 4 months through winter Australia, my clutch won't disengage, z650hybrid,
I've checked that the shaft from the clutch mech is actually pushing and adjusted correctly
I've had the motor running for 20min to get it warm and tapped the engine case with timber on the engine number area above the clutch, still won't free up.
I thought maybe use a hot air gun on the clutch through the filler cap and change the oil
any idears as to what can cause this?
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • keith1
  • keith1's Avatar
Re: clutch won't disengage
29 Nov 2008 16:12
#249959
time to pull clutch cover and see whats up...cost ya 1/2 hour and a new clutch cover gasket at a minimum.....good luck......keith
  • jimmybon
29 Nov 2008 16:47
#249964
tools are in hand and the gasket is ordered, Just thought I'd like to know whats causing the problem before i attack her
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
29 Nov 2008 17:00 - 29 Nov 2008 17:01
#249967
I've gotten past such a problem by tying the clutch lever to the grip for a few days and occasionally working the rear wheel back and forth while the transmission's engaged.
Most of the time the plates are just stuck with cold oil. I forget did you change the oil already? Was there any moisture in it?
As Kieth suggested, it's not difficult to disassemble the clutch plates, should you have to.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 29 Nov 2008 17:01 by KZQ.
  • jimmybon
29 Nov 2008 17:10
#249972
I here were your comming from with the moisture thing
I just got of the phone to a mate that had the same problem with hi GTS900 79 duke, he reckons its a moisture build up on the plates,
I'm going to warm the engine again and drop the oil and filter. While thats draining I'll scoot down to work and get the hot air gun
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • jimmybon
29 Nov 2008 18:16
#249977
OK, the heat gun was a waste of time
so I started to rock the back wheel wilst on the center stand with the clutch lever tired on, I can see the clutch though the filler hole move, as the wheel hit each end of the play in first gear, then I tryed to change the gears as i rocked the back wheel, slipped into neutral then 2nd the third then rocked a little harder and u could see that the pressure was increased to the clutch then she freedup
I'll put that gasket into stock
New castrol grand pri 15w50 mineral going in
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • keith1
  • keith1's Avatar
29 Nov 2008 21:05
#249994
sweet ...good to go....congrats....nice when something goes right and ya get a tad lucky.....
