- Thank you received: 88
Base Gasket Removal
- GregZ
29 Nov 2008 08:34 #249922
by GregZ
Base Gasket Removal was created by GregZ
Ok need some tricks of the trade for base gasket removal off 900 cyl. block.. Scraper? razor blade ? How many beers will it take??
This can't be fun
Thank in advance
greg
This can't be fun
Thank in advance
greg
- trianglelaguna
- Thank you received: 235
29 Nov 2008 08:40 #249926
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Base Gasket Removal
soak the gaskett with one beer .return to the couch and drink the other eleven.tomorrow the gasket will be ready to scrape.if nto you may want to repeat the process. sharp firm plastic scraper contact cleaner??
1976 KZ900
2003 ZX12R
2007 FZ1000
- PLUMMEN
- Thank you received: 104
29 Nov 2008 11:22 #249937
by PLUMMEN
Replied by PLUMMEN on topic Base Gasket Removal
toss it in the oven a few minutes with oven cleaner on it,put base of sleeves pointing up on pan so they dont slide up.
- bountyhunter
- Thank you received: 337
29 Nov 2008 13:28 - 29 Nov 2008 13:30 #249947
by bountyhunter
Replied by bountyhunter on topic Base Gasket Removal
GregZ wrote:
You can try putting brake fluid on it overnight. That eats most anything. Mine took about 4 hours of scraping with a blade (cylinder and crankcase)to get clean because the factory glued it with 3-bond which is indestructible to everything.
Use rags to block the crankcase openings so the scrapings can't fall in.
This can't be fun
Thank in advance
greg
Last edit: 29 Nov 2008 13:30 by bountyhunter.
- BohicaBob
- Thank you received: 35
29 Nov 2008 13:37 - 29 Nov 2008 13:38 #249949
by BohicaBob
Replied by BohicaBob on topic Base Gasket Removal
I like to use some dull wood chisels. A little WD40 helps keep the old gasket pieces together somewhat as I work them away from the gasket surface and away the piston/crankcase holes.
Last edit: 29 Nov 2008 13:38 by BohicaBob.
- shighley
30 Nov 2008 09:32 #250029
by shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
Replied by shighley on topic Base Gasket Removal
PermaTex makes/made a spray gasket remover. It works very well. Sort of looks like paint stripper working in that it bubbles. With two or three applications the gaskets lift off. It also removes the clear coating on engine side covers and probably would ruin any paint it contacts. Be careful! I've bought the stuff at Auto Zone, but if they still make it, it should be everywhere. Good luck and ride safe, Steve (probably should have 12 or more beverage units available for those unforeseen problems)
- H2RICK
- Is this a fun bike, or what!!!
30 Nov 2008 09:58 #250033
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Base Gasket Removal
A guy on another board I hang out on swears by stuff used to remove bathtub silicon seal. It's a spray and he just sprays some on, leaves it for about 10 minutes and then says the gasket just lifts off. I have NOT tried this (yet) myself but the cost for a trail run would be minimal, I'm sure.
I will be giving it a try the next chance I have.
I have/have used the Permatex gasket remover and it works as posted but it's pricey and you DO have to be careful with it. Do NOT use it in confined spaces because it's got some wild chemicals in it......and you don't want any future offspring with 12 fingers or anything like that....right??
- timebomb33
30 Nov 2008 13:02 #250061
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Base Gasket Removal
loctite gasket remover is what i use spray it on let it set for 5 min. come back scrap with razer blade spray again work on next layer repeat until gone don't get aggressive with the razor blade try not to gouge or nick the gasket surface if you try any mechanical methods you can remove aluminium as well as the gasket and cause your self problems with sealing when you put it back together. just take your time.it will come off,don't try rushing it.
- H2RICK
02 Dec 2008 12:11 #250398
by H2RICK
OK....here's the stuff I found at the Home Despots yesterday. I usually use an old piece of plexiglass from a broken windshield as a scraper but this scraper has a very
straight edge and it's quite sharp so should work a lot better....and be safer on metal surfaces. Total cost including the scraper is C$6.78 plus tax. We'll see how the Silicon-Be-Gone works on old gaskets and report the results by the end of the week.
