need Quick answer about cam interchange
- Buda
28 Nov 2008 22:27 #249879
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
need Quick answer about cam interchange was created by Buda
Will pre 81 cams interchange for 81 and after? Diffrent cam sprocket?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Mark Wing
- Thank you received: 22
28 Nov 2008 22:59 #249882
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic need Quick answer about cam interchange
On the 650's just swap out the sprockets.
Mark
Mark
Yorba Linda Cal.
- Buda
28 Nov 2008 23:13 #249884
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic need Quick answer about cam interchange
Thanks Mark but I need to know about the 1000s
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- steell
29 Nov 2008 06:30 #249908
by steell
Replied by steell on topic need Quick answer about cam interchange
To use pre 81 cams in 81 or later motors you need adapter sprockets as sold by APE.
Pre 81 cams have two bolts on the sprocket, 81 and later have three. Or vice versa
kzzone.com/sprockets.html
ACS1100K 1000J/ GPZ1100 adaptor sprockets. Uses hy-vo style cam chain with KZ style three bolt cams
- Buda
29 Nov 2008 08:52 #249929
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Thanks steel
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
