- Thank you received: 88
Splitting Cases:How to
- GregZ
27 Nov 2008 11:03 #249603
by GregZ
Splitting Cases:How to was created by GregZ
Can someone tell how to split cases. I have old 73 900 motor thinking (Fleabay)someone might need early 3 digit cases.The only thing there is the cases with crank and trans. Think I have all bolts out. what next??
- PLUMMEN
- Thank you received: 104
27 Nov 2008 11:07 #249604
by PLUMMEN
Replied by PLUMMEN on topic Splitting Cases:How to
where are you located?if youre close to nebraska imight be able to save you some work,serial nunber off cases?
- GregZ
27 Nov 2008 11:17 - 27 Nov 2008 11:20 #249607
by GregZ
Replied by GregZ on topic Splitting Cases:How to
Nevermind..couple whacks with BFH and it split serial number
Z1 E 00758
Z1 E 00758
Last edit: 27 Nov 2008 11:20 by GregZ.
- PLUMMEN
27 Nov 2008 11:29 - 27 Nov 2008 11:32 #249610
by PLUMMEN
eek,easy with that hammer!:laugh:i hate explaining how to split things apart incase something breaks,mystery bolts ats are a bitch!:laugh:
Last edit: 27 Nov 2008 11:32 by PLUMMEN.
- GregZ
27 Nov 2008 13:09 #249625
by GregZ
If anyone is interested in these cases please eamil me
mrgjanko@yahoo.com
mrgjanko@yahoo.com
- Old Man Rock
- Thank you received: 225
28 Nov 2008 06:50 - 28 Nov 2008 08:51 #249718
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Splitting Cases:How to
STOP Emmidiately.... Seriously!
There are four bolts that are off the main crank cap that are somewhat deceiving these also must come off... If you don't you'll end up like I did, broken case!!!!
The one manual I had didn't truly mention these (bolt counts) and I screwed up royal, blew a hole through the case....
Take your time, loosen these 4 bolts and then in using the 8mm case splitting bolts (attached) in the manuals you'll find the cases split rather easily.
OMR
These are the 4 additional bolts I was speaking of...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Nov 2008 08:51 by Old Man Rock.
