- Thank you received: 2
andrews 1x cams
- keith1
- racer54
- Thank you received: 114
- keith1
I believe the stock cams have a lift of ex. .297 and int. .320 or somewhere in that area. Read the stock head can flow up to around .360 before it becomes the choke point. You can run bigger in stock head but just not getting full benefit. I would guess that .344 lift should make enough difference that you can feel it and be noticeable improvement over stock, Should make a great street cam. Those pistons can handle much more lift so these cams are a drop-in.
thanks for the info.......
- kawsakiman
- Thank you received: 6
- keith1
go bigger. :woohoo:
cam size is commensurate with wallet thickness..
