78 kz1000 ltd timing marks not lining up.
- codsack
20 Nov 2008 20:00
Hows it going...this is my first post here and it's regarding the timing marks on the camshaft sprockets and the mark by the points. I tried getting the marks lined up down on the points area and something wasn't right on the cam sprockets.....so I lined up the arrow on the exhaust cam sprocket even with the head deck and counted back to the 28th pin. The "T" in the points area is not even close to where it's supposed to be.
Also, when the T is in line, it's supposed to be directly under the timing mark correct? And not the small mark to the right of the T??
Another questions (sorry), but when turning the crank on the stator side of the motor, is there supposed to be any movement before the crank/cams start to rotate?
Sorry if these questions have been answered before, never messed around with a kz before. I'm sure I won't have any problems building this motor, just wanna clear up some questions, and I'm sure there will be more in the future. Yeah I have a manual. Just wanna be safe. thanks guys, Chase.
- timebomb33
Re: 78 kz1000 ltd timing marks not lining up.
20 Nov 2008 22:22 - 20 Nov 2008 22:23
is there any way you can send a picture of your cams and of your points plate if not we will try to talk you thru this problem you have.if you would like e-mail me directly.by the way congrates on joining this site there is alot of knowledge here to be tapped in to.
I THINK MY POWERBAND BROKE
Last edit: 20 Nov 2008 22:23 by timebomb33.
- wiredgeorge
21 Nov 2008 05:56 - 21 Nov 2008 06:11
I would start by making sure the cam chain isn't balled up in the front of the engine down under the sprocket on the crank. You can do this by shaking the chain. Make sure you START with the timing mark under the derby cover aligned to the T lined up with the mark on the case. You mentioned turning the crank on the stator side? No sir... turn the crank using the 17mm nut on the points side with the spark plugs removed. Anyway, the T mark is lined up and you shake out the cam chain... then put the intake cam in place with the > mark lined to the gasket mating surface at the front of the engine. Then put the exhaust cam in place where the 28T mark is lined up with the 28th pin by counting the pin adjacent to the > mark as ZERO.
Last edit: 21 Nov 2008 06:11 by wiredgeorge.
- Sandy
- Fly High,Tony
21 Nov 2008 06:48
And make SURE that the bike is sitting level,and not on the kick-stand!
The cam chain won't grab the crank,properly,if the bike is on a lean.
1977 KZ1000 A-1
- codsack
01 Dec 2008 21:09
I know its late to reply, but I did sort it all out as far as the timing marks. I just wanted to be sure about it before I tore into the motor. thanks again for the reassurance, the fish.
