650 points cover needed
- cherrymetal
20 Nov 2008 03:59 #248462
by cherrymetal
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
650 points cover needed was created by cherrymetal
I'm trying to get hold of a points cover from an early model KZ650 (the ones with kawasaki in upper case)to go on my GPz engine'd KZ650. I keep missing them on ebay!
Anyone got one they'll part with, don't mind one that needs some cleaning and polishing, but nothing that has bad road rash. I'm in the UK, can pay paypal or whatever.
- MFolks
- Thank you received: 540
21 Nov 2008 13:29 #248682
by MFolks
Replied by MFolks on topic 650 points cover needed
Have you tried
www.oldkawman.com
He will part out a bike once in a while.
- loudhvx
- Thank you received: 1616
21 Nov 2008 15:00 - 21 Nov 2008 15:01 #248688
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 650 points cover needed
The old covers do look cool, but beware, on my 550 (which uses the same ignition area) I found the old points covers didn't give the same clearance over the advancer area as the newer electronic ignition covers. Just make sure there is no interference between the advancer bolt on the dome of the cover.
1981 KZ550 D1 gpz.
Other links.
Last edit: 21 Nov 2008 15:01 by loudhvx.
- cherrymetal
24 Nov 2008 04:02 #249114
by cherrymetal
Replied by cherrymetal on topic 650 points cover needed
thanks for the tips guys, it doesn't look as if oldkawman has anything like that for the 650/750 bikes at the mo, he only lists the plastics. I guess it might be worth an email.
