- Thank you received: 12
Kz 400 ignition advancer
- oldkaws4ever
- Have no regrets...... You only live once.
15 Nov 2008 23:03 #247675
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Kz 400 ignition advancer was created by oldkaws4ever
I was thinking this is why my bike has no kahunas at high rpm's, it just sputters and drops off and hit's on 1 cylinder. How do you check to see if the advancer is moving freely? I know it's a stupid question, but can't seem to find it in the manual. Thanks guy's, Jim
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Thank you received: 2098
15 Nov 2008 23:51 - 15 Nov 2008 23:51 #247684
by Patton
Replied by Patton on topic Kz 400 ignition advancer
oldkaws4ever wrote:
On the Z1 and KZ900 (and probably other models also), using a strobe-type timing light, watch the advancer move back and forth while changing the rpm.
... How do you check to see if the advancer is moving freely? ...
Last edit: 15 Nov 2008 23:51 by Patton.
- steell
16 Nov 2008 07:09 #247696
by steell
Replied by steell on topic Kz 400 ignition advancer
Grab hold of it with your fingers, twist it, then let go and watch it snap back to it's original position. If it does that smoothly then it's good.
By the way, a sticking advancer won't make the engine miss, it will just reduce power above 4k rpm or so.
A bad plug, plug cap, or plug wire, on the other hand, can make the engine miss at higher revs and load.
- oldkaws4ever
16 Nov 2008 11:19 #247760
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Kz 400 ignition advancer
Thats when it starts to run like crap right around 4000 and above. The right pipe gets warm but not hot, and the plug is black with a gas smell.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
