Cylinder Head Bolts
- jmargrav
15 Nov 2008 16:25 #247602
by jmargrav
1982 KZ750-E3
Lariamie Wyoming GO WYO!
Cylinder Head Bolts was created by jmargrav
Well I was putting my bike back together this weekend and when tightening down my head I snapped the head bolt. It was not one of the nuts that go on the studs, but one of the two head bolts. This is not the first time I have done this, yea I know should have learned my lesson, but I didn’t.
Now the manual I have says to torque them down to 22 ft lbs. But I only had my torque wrench at 10 ft lbs and they still snapped! So I was able to get the broken bolt out of the head without removing the head, but what should I be tightening these head bolts to. I did a search and found some people recommending 6 ft lbs, just to be sure, is 6 ft lbs enough? Too much?
1982 KZ750-E3
- timebomb33
- Thank you received: 10
15 Nov 2008 17:02 #247603
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cylinder Head Bolts
if they are the 6mm bolts on the end of head use no more than 7.5lbs of torque.
- bountyhunter
- Thank you received: 337
15 Nov 2008 17:24 #247612
by bountyhunter
Replied by bountyhunter on topic Cylinder Head Bolts
My 750 has three small 10mm bolts that go up from below into thre head and they look a lot more sturdy than the ones pictured. My manual specs those to torque at about 8 ft-lbs.
- RonKZ650
- Thank you received: 240
15 Nov 2008 18:04 #247623
by RonKZ650
Replied by RonKZ650 on topic Cylinder Head Bolts
Yes the manuals are sadly mistaken on torque for that bolt.
- jmargrav
16 Nov 2008 14:28 #247801
by jmargrav
1982 KZ750-E3
Replied by jmargrav on topic Cylinder Head Bolts
Well I will have to be more carful the next time, I guess the bolts just have to hold back some oil, well thanks for confirming my suspicions.
1982 KZ750-E3
