Head Gasket Replacement from oil leak KZ1000
- 77oldkaw
I have read the process of changing the head gasket in the manual and feel fairly comfortable in doing it myself.
1) Would you use any gasket sealers on the head or valve covers? There are so many opinions, but I sure don't want to have to do it again.
2) With so few miles and it has been running well, is it recommended to check valve clearances, or is that only necessary for higher miles?
I would appreciate any insight
- Sandy
- Fly High,Tony
- Thank you received: 13
Just for the hell of it,try torquing the head nuts,and see if that makes a difference,before you tear the top end off.You MAY get lucky.
And yes,you probably should check the valve clearances with 15k on the clock.You don't know if and when it was done last.
1977 KZ1000 A-1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
Kawi put some small 10mm bolts pointing upward into the head at the very front and rear on my engine so they clearly knew about the problem.
As far as sealers, a head gasket should not need it. If it continues to seep, they do make copper based spray on sealers that may help.
My "fix" is to roll up a small section of paper towel and use a popsicle stick tp force it in between the fins at the front where the gasket seeps to keep the oil from migrating left and right.
- timebomb33
- bountyhunter
I thought all the OEM type head gaskets for the bigger Kawis were copper sheets over fiber innards. Mine is.copper coat only works on copper gaskets all it does is fill in imperfections in the copper.
- timebomb33
- Tony
blown head gasket
Definitely don't use sealant on the head gasket and don't use sealant on the valve cover gasket.
Checking valve clearance is a very simple maintenance task. You should check your valve clearance.
- 77oldkaw
- Sandy
- Fly High,Tony
I am tearing it down to powdercoat the frame and will know in a month or two if that cures the leak. Thanks again
Just so you know,powdercoating the frame won't cure an oil leak.:laugh:
1977 KZ1000 A-1
- Old Man Rock
- Thank you received: 225
Question, why not use a very light coat of gasket sealer in conjunction with your gaskets?
Wouldn't that fill in small blemishes, nic's, imperfections and such...
Edit NOTE: I realize that spec dictates not required, don't use but on a 30 year old bike and if the cases aren't not true, is there a problem with using a sealer should be the question.
Not trying to start a flame war, just trying to educate my old ass mind... Knowledge is power....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
