- Thank you received: 337
How To Fix cam Drive Leak?
- bountyhunter
Are there O rings in there that have to be replaced to stop it from leaking?
Any repair kits available?
Anybody know how the O rings come out and go in?
- keith1
- Thank you received: 2
- Thank you received: 2098
KZ750 twin tach drive
Good Luck!
- bountyhunter
They show a tach gear gasket and an oil seal I don't remember seeing.... the machine shop took the drive gear out and replaced it after the hot tanked the head. Does the gasket and seal stay captive in the guide when you pop the gear in and out? Those chemicals may have eaten them alive....:ohmy:
- RonKZ650
- Thank you received: 240
Here's an earlier thread with some excellent information and advice from steell.
Good Luck!
Hello? ... Hello?? ... Tap ... Tap ... Tap! Is this thing on? :laugh:
- bountyhunter
Good Luck!
I read the whole thread and it didn't tell me what's up with the invisible gasket or how to change the seal. This does:
RonKZ650 wrote:
The seal is part of the main body of the drive, has to be pried out with a little pick. The oring seals the body to the head. The gasket is always missing because first time the tach cable is removed it is not noticed and lost. It looks like the seal and gasket is the same as all the other more common KZ650s and 1000s, but the oring is different, but both are 10mm. My guess is you buy the kit for the KZ1000 it would fix a 750. You can buy this stuff at Z1 ent I'm sure. You can make your own gasket out of thin cardboard.
Thanks for the info, that's exactly what I needed to know.
