Kerker vs V&H ground clearance KZ1000
14 Nov 2008 18:41 - 14 Nov 2008 18:57 #247439 by Exitpupil
Kerker vs V&H ground clearance KZ1000 was created by Exitpupil
Can any KZ1000 owners with a late model Kerker 4 into 1 (model KE2156) measure from the bottom frame tube how far down the Kerker hangs down? I have a V&H and it did hang 4" below the frame tube, it is now 3-7/8", from shedding sparks!
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Last edit: 14 Nov 2008 18:57 by Exitpupil.
14 Nov 2008 18:48 #247442 by keith1
Replied by keith1 on topic Kerker vs V&H ground clearance
vance and hines pic from when i first put it on...hope it helps.....keith
14 Nov 2008 19:00 - 14 Nov 2008 19:00 #247445 by Exitpupil
Replied by Exitpupil on topic Kerker vs V&H ground clearance
Keith you have the same pipe I do. I am trying to find out if the Kerker fits tighter under the bike? I need some measurements please guys. In God we trust, all others bring data. Nice looking bike BTW.
Last edit: 14 Nov 2008 19:00 by Exitpupil.
14 Nov 2008 19:00 #247447 by keith1
i guess my pic is not a help since your edit...:unsure:
14 Nov 2008 19:02 #247448 by keith1
thanks...i thought a pic would do, but as i have my bike in pcs right now i guess a tape measure wont do either of us any good.....as you were....
14 Nov 2008 20:06 #247470 by PLUMMEN
Replied by PLUMMEN on topic Kerker vs V&H ground clearance
didnt have a tape measure at the time,but i can safely say you will have amuch harder time dragging the kerker;)
14 Nov 2008 22:17 #247488 by MDawnz1
Replied by MDawnz1 on topic Kerker vs V&H ground clearance KZ1000
Question.......
How much do you weigh ?Over 165 ?
Do you ride 2 up often ?
Sounds like you might just be overpowering your suspenstion .
1974 Z1a, still 903
15 Nov 2008 04:11 #247512 by PLUMMEN
Replied by PLUMMEN on topic Kerker vs V&H ground clearance KZ1000
the vance and hines is just layed out differant under thke,i had same problem with my ltd;)
15 Nov 2008 13:55 #247578 by timebomb33
Replied by timebomb33 on topic Kerker vs V&H ground clearance KZ1000
did you bottom out and it scraped or were you leaned over when this happened.
I THINK MY POWERBAND BROKE
15 Nov 2008 17:20 - 15 Nov 2008 17:20 #247610 by Exitpupil
Replied by Exitpupil on topic Kerker vs V&H ground clearance KZ1000
Timebomb, My bike is lowered exactly 1". Forks slid up in trees 1" and rear shocks 12". Progressive springs in front and rear. The pipe drags when the suspension is loaded in a right hand turn. Going hard into a downhill righthander and hit a bump and YIKES not a good time to drag. I had an old pipe from the around 1980 I think was a Kerker? that had a big S turn under the bike and it dragged the same as the V&H. I was eyeing the new Kerker shaped like the V&H and hoped someone could put the tape on it. I am not forking out nearly $500 for no clearance gain. BTW I have lifted weights for 30 years so I am up to 185 lbs(I'm 5'-7" hence the need to lower it).
Last edit: 15 Nov 2008 17:20 by Exitpupil.
15 Nov 2008 17:32 #247613 by timebomb33
your lowered an inch in the front and an 1 1/2" in the back i have an old yosh pipe on mine and i never have a problem mine is lowered about the same i weigh about 210 and when i go for a trip i probably have about 50-60lbs of gear with me. i've never had a problem with clearance so that pipe must be a little more tucked out of the way.my bike is about a thousand miles away but i can check on it at christmas if you would like. i also have another bike with a kerker and i can check it against it as well. in the mean time you might want to add a bunch more preload on those back springs. it could be just a bit to soft for your weight and compressing just enough to cause you problems.
15 Nov 2008 17:38 #247616 by gane
Replied by gane on topic Kerker vs V&H ground clearance KZ1000
Exit, Not sure my P/N, But, purchaced my kerker 4/1 last summer new from Parts Unlimited, it's new enough to have the aluminum baffle endcup if that helps,clearance from bottom of trans pan to lowest portion of collecter is uniform 3.5 inches, and same from lower frame rail just before rear upward bend. If I recall correctly Kerker & V/H are dramaticly different in both collector and muffler config's with Kerker sweeping away from oil filter cover and muffler sweeping up and in just after brake pedal. I've yet to touch exhaust tho 'tis inevitable, I hope its just a case of speed bump when I do, Hope this helps.G
[img][/img] 1977 KZ1000A1
