- Thank you received: 2
oil pan removal
- keith1
14 Nov 2008 18:22 #247437
by keith1
oil pan removal was created by keith1
it looks easy enough, but i think i remember hearing some tales that it doesnt drop easy...anyone have any experiences they want to share..also, i took a quick look around and i dont see anyone carrying oil pumps....maybe i just didnt look hard enough.....thanks .... keith
- bountyhunter
- Thank you received: 337
14 Nov 2008 19:10 - 14 Nov 2008 19:13 #247450
by bountyhunter
Replied by bountyhunter on topic oil pan removal
I'm pretty sure my oil pan came from kawi with 3-bond on it and it was a bugger to get off. I think you can use a pocketknife blade worked into the corners to try to get some separation and the pry it apart. Scraping the gasket remnants off is 3 hours of your life you'll never get back.
On the KZ's, the oil pumps don't usually wear out. You can order the new pump drive impellers from Kawasaki, that's what I did.
Last edit: 14 Nov 2008 19:13 by bountyhunter.
- kawsakiman
- Thank you received: 6
14 Nov 2008 19:13 #247452
by kawsakiman
Replied by kawsakiman on topic oil pan removal
don't forget to get the two oil pump seals if you remove the pump.
you will never get it to seal with the old ones.
- bountyhunter
14 Nov 2008 19:14 #247455
by bountyhunter
kawsakiman wrote:
Yep, on mine it was a wierd O ring with a cone shaped side to it.
- keith1
14 Nov 2008 19:15 #247456
by keith1
Replied by keith1 on topic oil pan removal
thanks, i was just thinking since i had it semi apart....i will probably just leave well enough alone.
lite always went out in a timely fashion and never came on when it should nt..........
- rstnick
- Thank you received: 377
15 Nov 2008 10:41 - 15 Nov 2008 10:42 #247546
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic oil pan removal
I changed my oil pan last Winter.
I layed the bike on her side to replace the Oil Pan. I used a couple of car tires to lay her over gently. The battery is out the of bike, oil as well, Tank and side cover off:
A few taps with a rubber mallet helped loosen her up.
Made cleaning off the old gasket much easier.
Other pan on:
Other pan on:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 15 Nov 2008 10:42 by rstnick.
- timebomb33
- Thank you received: 10
15 Nov 2008 11:23 #247550
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic oil pan removal
i hope you changed the rear tire . that is excactly how i pull the pan off my drag bike when im checking shift forks easy that way isn't it .
