Kz 400 clutch release lever bad??
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
12 Nov 2008 22:13 - 12 Nov 2008 22:49
#247143
The clutch on my kz 400 is extremelly hard to pull in, and the release lever under the sprocket cover sticks and dosent move freely. I have lubed it to no end and it still dosent move freely. Is the release lever the same on the 650, 900, and 400 the same one? It looks like it is but i dunno.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 12 Nov 2008 22:49 by oldkaws4ever.
  • oldkaws4ever
Re: Kz 400 clutch release lever on a kz 400 bad??
12 Nov 2008 22:32 - 12 Nov 2008 22:33
#247148
Just went on kawasaki.com and here are the bikes that use the same part.
Please wait ...
Model (22):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ400 (1974)
KZ400-A1 (1977)
KZ400-A2 (1978)
KZ400-D (1975)
KZ400-D3 (1976)
KZ400-D4 (1977)
KZ400-S (Special) (1975)
KZ400-S2 (Special) (1976)
KZ400-S3 (Special) (1977)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
Z1 (Z1) (1973)
Z1-A (Z1) (1974)
Z1-B (Z1) (1975)
Does anybody have one from a bike thats in the list that they wanna sell? Let me know
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 12 Nov 2008 22:33 by oldkaws4ever.
  • PLUMMEN
  • PLUMMEN's Avatar
12 Nov 2008 22:36
#247150
try taking it apart and cleaning really good then lubing it up,could just be old gunky grease;)
  • oldkaws4ever
12 Nov 2008 22:48
#247151
I have did that 3 times today and it didnt get better anytime after i did it.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • MFolks
  • MFolks's Avatar
13 Nov 2008 12:30
#247219
On my 82 GPZ1100 B2 under the sprocket cover is the clutch release mechanism. Over a period of years the pivot worn where the clutch cable attached the the rest of the actuation system.
I drilled out the pivot rivet and used a high strength bolt as a pivot and have used it for several years with no problem. I think the bolt is 1/4" in diameter. I lube it when I do work under the cover and it's working well.
  • keith1
  • keith1's Avatar
13 Nov 2008 14:17
#247233
does your bike use the pushrod to actaute clutch?
if its dry, could be a contributor?....just taking a whack at helping!.......keith
Re: Kz 400 clutch release lever bad??
13 Nov 2008 14:57 - 13 Nov 2008 15:00
#247237
oldkaws4ever wrote:
The clutch on my kz 400 is extremelly hard to pull in, and the release lever under the sprocket cover sticks and dosent move freely. I have lubed it to no end and it still dosent move freely....
Am uncertain about which parts are sticking and not moving freely. :unsure:
Perhaps this diagram could be used as a reference. :)
[Click on diagram for larger view]
Last edit: 13 Nov 2008 15:00 by Patton.
  • oldkaws4ever
13 Nov 2008 17:36
#247243
#6 slides into #4, and #4 goes in but gets stuck when it bottoms out.......if that makes any since. Plummen is sending me one of his, so i will let you all know if that was the problem, when it gets here and i get it on. Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
