Too much oil?
- stickboykings
12 Nov 2008 13:19 #247076
by stickboykings
Too much oil? was created by stickboykings
Went to work Friday on my 1982 KZ1100 after putting in a small amount of oil (it appeared to be low). No problem going to work, but on the way home, whenever I got up to about 3000-3500 RPM power would drop out and RPMs dropped to about 2000. The bike stuttered and then regained power. This happened 3-4 times and then at the corner of Crackhead and Wino, it just died. Tried to start and not even a "click". Waited a bit and it started up like nothing ever happened.
Can too much oil cause that? I have had some carb issues recently, but they've never shutdown the bike (just farts and small backfires).
Thanks guys. I love reading all the information in these forums. Thought I'd post this one since it was my everyday rider and now I'm a worried man. :blink:
- MFolks
- Thank you received: 540
12 Nov 2008 13:45 #247078
by MFolks
Replied by MFolks on topic Too much oil?
Troubleshooting a bogging problem can be very time consuming as it might be as simple as a clogged fuel filter,bad gas,ignition coil(s) breaking down,sparkplug wires grounding out,and/or sparkplug caps failing.
I'd drop the float bowls and look for sediment in the bottom of them, also check the fuel flow from the gas tank petcock(fuel control valve)If these all check o.k. then pull #1 sparkplug, ground it against the engine and crank it looking for a hot fat spark.
If the spark is weak you may be a candidate for the "Wired George Relay Modification".
His website is www.wgcarbs.com and on it lists parts and how to accomplish this wiring mod.
- Thank you received: 2098
12 Nov 2008 14:27 - 12 Nov 2008 14:46 #247086
by Patton
Replied by Patton on topic Too much oil?
Symptoms might also result from fuel starvation caused by clogged vent in fuel tank cap. Could test run with fuel cap ajar (not snapped down), and see if that makes any difference. And -- duh -- be sure there's plenty of fuel in the tank. :laugh:
Might need to flush out the fuel tank if there's grit or crud inside which sometimes hovers around and blocks the petcock intake tube screens.
Would also check for clean tight battery cable terminal connections, and also for a good ground connection where the negative cable attaches to the engine or ground. And the temporary failure to even "click" may indicate some other wiring problem or loose connection.
Best not to overfill the oil, of course, but I don't suspect the oil level is causing the current problem.
Good Luck!
Good Luck!
Last edit: 12 Nov 2008 14:46 by Patton.
- bountyhunter
- Thank you received: 337
12 Nov 2008 15:32 #247098
by bountyhunter
Replied by bountyhunter on topic Too much oil?
Definitely sounds like a fuel problem. Mine would do that when crud would get in a main jet then flush itself loose.
- HerrDeacon
- Thank you received: 1
12 Nov 2008 15:40 #247099
by HerrDeacon
Replied by HerrDeacon on topic Too much oil?
I echo what Patton said. I had a similar problem and found out it was the gas tank vent hole was blocked. Took it apart and cleaned it, seemed to solve the problem.
Best of luck.
Best of luck.
- stickboykings
12 Nov 2008 17:55 #247123
by stickboykings
Replied by stickboykings on topic Too much oil?
Thanks guys! At least my mind is clear on the oil thing. Based on several of the replies, I'm leaning towards the fuel issues. When I originally examined the carbs, there was a bit of very fine rusty sediment in the bottom of the float bowls. The fuel line is new (and clear blue) and the fuel filter is brand new (and clear as well) and I don't see any gunked-up issues there.
I have not removed the petcock for a look since I painted the tank a year ago (so that screen could be clogged now too).
I'm not too sure about cable issues since I never had any indication that I lost electrical contact (but I will check the connections anyway to be sure they're golden).
Now the gas tank vent hole is interesting because I hadn't changed (nor inspected) that line or the petcock vacuum line.
Thanks again for the leads. Mucho appreciated!
- bill_wilcox100
12 Nov 2008 18:16 #247125
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Too much oil?
As already suggested, do the WG Coil Repowering modification. It will improve starting and running immediately and is insurance against deteriorating electircals.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
- gane
12 Nov 2008 19:07 #247129
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Too much oil?
Stickboy, If you're running stock airbox, you might look to intake. i had similar symptoms on my gsf12, when it tryed to ingest my rear tankbag strap,G
- Thank you received: 2829
14 Nov 2008 16:52 #247423
by 650ed
Replied by 650ed on topic Too much oil?
Make sure your hose isn't kinked (ouch!).
- MDawnz1
- Thank you received: 27
14 Nov 2008 22:25 #247489
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic Too much oil?
You answered your own question ,,,,,,,,,,,,,
"NOT EVEN A CLICK" ,,,,,,,,,,,
That's electrical .
That's electrical .
1974 Z1a, still 903
- 78z1Joe
- My man cave is my garage....
- Thank you received: 21
17 Nov 2008 18:09 #248017
by 78z1Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Replied by 78z1Joe on topic Too much oil?
I agree. I think it is electrical too. Check the battery terminals, make sure they are clean. Also check the battery itself, if a cell is dead, or sulfated, it will lower the voltage and the bike will run, but will miss at running RPM, 3 grand and above. Also the plugs might foul and the engine may backfire. The starter probably will not spin fast enough to start, but the bike will start if kicked, if it has a kick starter. Use a volt meter and check the voltage of every cell, 2.2 volts each.
Also, it is possible for the starter button to stick or corrode in the start (pushed in) position. This might cause the starter to run continuously,and drain down the battery even while you are riding. Again, the bike will miss or hesitate at speed. You should be able to hear the starter engaged at idle, it is a terrible grinding noise. Quick fix is to disconnect the heavy red wire from the battery to the starter solenoid, at the solenoid. This will allow the alternator to charge the battery and the bike should run fine again. Don't ask how I know this. Good luck:)
1978 KZ 1000
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- stickboykings
21 Apr 2009 10:27 #283664
by stickboykings
Just a follow-up to kinda close this thread. The problem never reoccurred. I checked all that you guys suggested (so thanks for the leads!) The only modification I made was to trim down the length of the fuel line.
Thanks for all the responses!
