650 to 750
- EarthShaker
11 Nov 2008 16:19 #246889
by EarthShaker
First to fight, Last to leave
1976 kz650 runs but still needs finishing
1976 kz650 basket case project
650 to 750 was created by EarthShaker
I got a 76 kx650 that i want to make fast and I saw an opportunity to get a 80 kz750 engine how much of it can i use to convert the 650 to an 810? are the cams better what about the transmission?
- timebomb33
- Thank you received: 10
11 Nov 2008 16:36 #246893
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 650 to 750
swap engines it should bolt right in.
- PLUMMEN
- Thank you received: 104
- jordan
- Thank you received: 5
11 Nov 2008 19:56 #246940
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic 650 to 750
unless you are absolutely set on keeping the kickstarter, i would just swap motors. They will bolt up the same, and everything else should work. I think you will have to get a 530 front sprocket because i know my 82 750 had a 630 sprocket but maybe the earlier 750's are different. If you want to keep the kickstarter it isnt a whole lot more work since you will have to take the top end off anyways to do the 810 kit. You will be able to have the 750 cylinders bored over and put ontop of your 650 cases. Also, the 750 head/cam combo will fit right up too. oh, and yes the 750 cams are better than the 650's. You will also have to put the 650 cam sprockets onto the 750 cams if you choose to run your 650 bottom end
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
11 Nov 2008 21:03 #246957
by timebomb33
listen to jordan he knows of what he speak's having done this before himself.
- jordan
11 Nov 2008 23:20 #246974
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
thanks timebomb, I only know this stuff because i once was in this same position with many questions. I was helped greatly by everyone on the site with my project and it is only my duty to share with others who now need help.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- cafekz750
12 Nov 2008 11:25 #247060
by cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Replied by cafekz750 on topic 650 to 750
To use the 750 jugs on the 650 bottom, you will also have to clearance the 650 cases to accept the liners.
Link to a thread about this
