650/750 Valve Cover Compatibility
  • reborn650
  • reborn650's Avatar Topic Author
Re: 650/750 Valve Cover Compatibility
20 Feb 2006 13:28
#25146
Thanks gang-Any suggestions on how to block the exhaust ports so I can use the polished 650 valve cover to retain the stock look?
The 4 circled ports in the pic need to be plugged if possible.
Cheers-Colin Firth -Ontario Canada
Post edited by: reborn650, at: 2006/02/20 16:38
-1998 Jeep TJ Wrangler 4.0...
  • loudhvx
  • loudhvx's Avatar
20 Feb 2006 14:42
#25151
If you do a search, you'll find a post where someone threaded allen plugs. I think they were pipe thread. It looked really nice.
I tried to search, but the search feature blows.
Post edited by: loudhvx, at: 2006/02/21 12:47
  • steell
  • steell's Avatar
20 Feb 2006 14:44
#25152
Two ways that come to mind at the moment.
Thread the holes with a pipe tap and use a flush pipe plug.
Plug them with JB Weld or similar epoxy.
  • reborn650
20 Feb 2006 14:53
#25155
Steell-I like the idea of tapping it, threading in a proper sized bolt and grinding the top off flush. Does this sound like it will work? I am hopeful that by plugging these 4 ports I won't be causing any back pressure buildup on clearing the exhaust from the combustion chamber.
If this is an issue then I will probably stick with the Kz650 head but swap cams. valves and springs.
Cheers-Colin Firth Ontario Canada
  • loudhvx
  • loudhvx's Avatar
21 Feb 2006 09:37
#25337
It won't cause any "back-pressure build up". Exhaust did not flow through these ports. Fresh air flowed INTO the exhaust through these ports.
  • steell
  • steell's Avatar
21 Feb 2006 11:09
#25358
I did not mean to repeat what Lou said, he just types faster :D
Yeah, threading the holes, screwing in a bolt and gring it flush is a common way to plug them, just be real careful not to mess up the gasket mating surface.
I'd thread the hole, screw a bolt in with my fingers, mark the bolt where it meets the surface, remove the bolt then cut it to size and cut a slot for a screwdiver in the top, then coat it with Loctite and screw it down flush.
  • wireman
  • wireman's Avatar
21 Feb 2006 14:13
#25400
how about brass plug,you can buy them slotted already from hardware store.;)
  • steell
  • steell's Avatar
21 Feb 2006 15:51
#25433
Because by the time I got to the hardware store and back I'd already have them done and be working on something else :D
Oh yeah, plus I'm a triple A rated cheapskate and the nearest hardware store is 10 miles away :evil:
Post edited by: steell, at: 2006/02/21 18:53
