650/750 Valve Cover Compatibility
- reborn650
Cheers-Colin Firth
I've attached two pics to explain
-1998 Jeep TJ Wrangler 4.0...
- reborn650
- RetroRiceRocketRider
- Thank you received: 29
I was considering doing the same on my ZN since I have an extra 650 valve cover and also noticed the different bolt pattern. That in itself was enough for me to even attempt to try to make it fit.
- steell
I assume this is the topic you originally posted in the other thread? Next time don't delete the subject line, leave it and delete everything else and I'll delete it for you. Made it awful frustrating trying to get to a post with no subject to click on
- reborn650
I am planning on retaining the 650's original cam chain and accessories and putting the 650 sprockets on the 750 cams. So the 650 valve cover will fit on the 750 head-correct?
Post edited by: RetroRiceRocketRider, at: 2006/02/18 18:48
The extra bolts just hold the little cover on, they don't go all the way through.....
Actually the two outer bolts (6x65) are different than the two inner bolts (6x22) and DO go through into the cylinder head (see pic below of my ZN....don't mind the dirt, I'm still cleaning the engine ).
And all the early 80's 750 models I checked on the Kawi site show the same.
I don't know if that would have any affect on securing the valve cover to a leak-free status or not though.
Do you think it still might work though, steell?
Because I'd be willing to give it a try as well to eliminate the rubber caps I have on the reed vent openings on my bike.
Had to repost because I attached the wrong pic...oopps! :whistle:
Post edited by: RetroRiceRocketRider, at: 2006/02/18 18:49
- RonKZ650
- Thank you received: 241
- reborn650
- loudhvx
- Thank you received: 1615
The ports line up with these protrusions on the cover.Where exactly are these holes located that would have to be plugged to prevent exhaust leaks? I don't have a Kz750 head to physically inspect, only a pic. If possible please circle the location and repost the pic if this can be done. Thanks-Colin Firth -Ontario Canada
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- svt522
- loudhvx
1981 KZ550 D1 gpz.
Other links.
