need help ID'ing a part
  • kz750fourAlaska
  • kz750fourAlaska's Avatar Topic Author
  • Gary (and Tim when he's home from college)
09 Nov 2008 21:10
#246586
I removed the oilpan on Tim's 1980 KZ750-four and found a broken part lying in the bottom of the oilpan. It appears to be made of hard plastic molded around a metal piece and is apparently a piece broken off of a larger part. Can anyone tell me what it is and where to access where it belongs, to replace it? I will try to post a picture or two. This bike is sort of a basket-case we are trying to resurrect; however I have started the engine with this part presumably already broken off from wherever it belongs. Thanks.
1980 KZ750H-four-(LTD)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: need help ID'ing a part
09 Nov 2008 21:23 - 09 Nov 2008 21:25
#246587
It is probably number 14 or 15...see www.kawasaki.com for your very own diagram:)
www.kawasakiepc.com/SSIView.cfm?cNodeID=83134&W=500&H=500&P=1
And to replace it, you'll have to pull the head and jugs:(
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 09 Nov 2008 21:25 by Mcdroid.
  • kz750fourAlaska
09 Nov 2008 22:57
#246588
Thanks Mcdroid, It matches up with the bottom inch or so of part #14, the front cam chain guide. Since the surface facing the camchain has very little if any wear on it I speculate that this happened a long time ago, perhaps even at the factory. Maybe it's been bouncing around in the oilpan for most of this engines 17K miles. Thanks again.
  • timebomb33
  • timebomb33's Avatar
10 Nov 2008 11:05
#246637
they will break if there is extra play in the cam chain
I THINK MY POWERBAND BROKE
