parts list for starter clutch rebuild
- kz750fourAlaska
- Gary (and Tim when he's home from college)
09 Nov 2008 20:21 #246580
by kz750fourAlaska
1980 KZ750H-four-(LTD)
parts list for starter clutch rebuild was created by kz750fourAlaska
When my son comes home for Christmas break our plan is to replace/rebuild the starter clutch on his 1980 KZ750H/E (four). In anticipation of that event I thought I'd drop the oilpan and take a look to see if it's obvious what parts would need to be replaced so I could order them. It can take days/weeks to gets parts to Alaska. Well with the oilpan off now and looking at the starter clutch area from the underside, there are no obviously messed up parts. (the way it grinds I expected to see chewed up parts all over the place). So the parts I'm sure we will need are three each of ROLLERS, PINS, and SPRINGS, as well as GASKETS for right side clutch cover & oilpan. Does anyone know what the likelihood is that we will also need to replace the 58T STARTER SPROCKET and/or the CLUTCH-ASSY-ONEWAY? On one hand I hate to order a $75 part if we don't need it but then again if we do need it, it may not arrive in time to finish the job before Tim heads back to college. Any thoughts on this from any of you who have already done this repair?
- MFolks
- Thank you received: 540
09 Nov 2008 20:55 #246584
by MFolks
Replied by MFolks on topic parts list for starter clutch rebuild
Contact
www.z1enterprises.com
for parts. www.kzzone.com,www.dynoman.net,www.sudco.com,and
www.redlinecycle.com
, www.partsnmore.com,www.vintagecyclepart.com are other websites to try.
- roy-b-boy-b
- Thank you received: 103
10 Nov 2008 04:19 #246592
by roy-b-boy-b
Replied by roy-b-boy-b on topic parts list for starter clutch rebuild
There was a starter clutch on eBay for cheap. I think it was for a 900 but the small parts might interchange. I think i have used 650 small parts before. Roy
- OnkelB
- Thank you received: 80
10 Nov 2008 07:28 #246614
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic parts list for starter clutch rebuild
roy-b-boy-b wrote:
The springs and plungers may be the same, but the rollers are different sizes between the 650/750 and the big bikes.
- fmergey
10 Nov 2008 08:54 #246621
by fmergey
Replied by fmergey on topic parts list for starter clutch rebuild
I did the same job on a KZ650. I ordered the rollers and the springs first. Assembled everything it did the same wrattling noise. At the end I had to change the all assembly and the sprocket. I could not find any documentation about the wear limit of the sprocket and the rollers. From my personal experience, and since lead time is an issue for you, I would suggest to replace the all assembly plus the sprocket.
Good luck.
Fred
Good luck.
Fred
- timebomb33
10 Nov 2008 11:48 - 10 Nov 2008 11:49 #246642
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic parts list for starter clutch rebuild
normally what happens with starter clutches is over time the bearings will flat spot and the bearing surface will do the same so normally you have to replace both components at the time. the flat spoting is what is causing it to stay engauged. so replace the rollers and ring gear assemblly and you should have no more problems.
Last edit: 10 Nov 2008 11:49 by timebomb33.
- gane
10 Nov 2008 17:18 - 10 Nov 2008 17:23 #246689
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic parts list for starter clutch rebuild
Gary, The most common failure w/starter clutches is/are what appear to be minute divots on the inner sprag surface,causing rollers to bounce instead of lock. thus a spinning starter and intermittant knocking sound from general area. I recommend a new inner sprag and rollers. if caps run smoothly in bore, and springs are intact, they and their recievers are seldom the problem, tho due to the time & effort to get there, you must be the judge. G
Last edit: 10 Nov 2008 17:23 by gane.
- kz750fourAlaska
01 Jan 2009 20:01 #255728
by kz750fourAlaska
Replied by kz750fourAlaska on topic parts list for starter clutch rebuild
Well, we did it!
Thanks to all for the above advice. We went ahead and had on hand the entire clutch assembly including the large sprocket. We did it with the engine remaining in the frame. Removed left (chain sprocket) cover, alternator cover, exhaust, clutch cover, clutch, oilpan, and oil pump. Had to make the clutch holder tool to get the 30mm nut off. Secondary shaft slid out smoothly. Replaced all clutch parts as mentioned, and it went all back together without a hitch, well maybe some small ones. Now it turns over easily, every time, no grinding or spinning as before.
