Engine Sprocket Cover - Race
  • supercharged
  • supercharged's Avatar Topic Author
09 Nov 2008 11:01
#246475
Need some help.
I'm looking for a replacement engine sprocket cover similar to ones on race bikes. I have found some similar to PMFRs as seen here , but wantd a full cover.
It appears that ZomibieCustoms has one on his bike as seen here
Anyone have a lead on where I can get one?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Engine Sprocket Cover - Race
09 Nov 2008 12:42 - 09 Nov 2008 12:51
#246491
Zombiecustoms has an outboard bearing support for his off set front sprocket.
You could fashion your own. You would need to get some aluminum plate and some round tube for the spacers. I got the material I'm making my custom bearing support from Speedy Metals .
I also compare prices with Metal Depot and Online Metals and a few others. Also make sure you go through check out to get shipping rates and sometimes one place will have cheaper prices on the material but more in shipping rates.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 09 Nov 2008 12:51 by StreetfighterKz.
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
09 Nov 2008 15:22 - 09 Nov 2008 15:23
#246510
here's mine if it helps.
Last edit: 09 Nov 2008 15:23 by kano.
  • racer54
  • racer54's Avatar
09 Nov 2008 16:12
#246517
SchnitzRacing.com sells them. Look under "Outboard Bearing Support". Here is a shortcut.
secure.mycart.net/catalogs/catalog.asp?p...27243&showprevnext=1
  • PLUMMEN
  • PLUMMEN's Avatar
09 Nov 2008 16:37
#246524
if you have a welding shop close by they are normally a lot cheaper than those metal supply places to find material at.;)
  • supercharged
09 Nov 2008 17:13
#246527
Thanks - That is what I was looking for... a full plate. Do you know if this works for stock countershaft sprocket. Now that I found this and saw that Pingel or Kosman may have it, but there they reference the full plate as a support to the offset countershaft sprocket required for wide swingarm/tire.
I guess I'll give Schnitz a call on Monday...
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • racer54
  • racer54's Avatar
09 Nov 2008 18:24
#246556
Should work just fine for a stock sprocket. Never did it but these have a boss to support a sprocket that has a "nose" on it that holds a bearing. You just wouldn't use that part and it would just be a cover. This cover gives the sprocket a place to anchor to that supports the outside end of the sprocket as it implies. You won't gain anything over a stock sprocket cover except for the look if you use a stock sprocket though. These are made for 5/8" offset sprockets. You don't need the support feature this has for the stock sprocket or even a 3/8 offset sprocket.
  • supercharged
09 Nov 2008 19:24
#246570
Thanks - If I go in this direction, the Kosman is a bit more beefy with Engine and outer plate for a few bucks less. www.kosman.net/page14.htm
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • timebomb33
  • timebomb33's Avatar
10 Nov 2008 12:31
#246647
d&g chassis builds a nice one as well that is what i have on my big bike.
I THINK MY POWERBAND BROKE
