timeing adjustment?
- BigBlockT
09 Nov 2008 09:17 #246467
by BigBlockT
timeing adjustment? was created by BigBlockT
not to sound like a dummy does it matter which plug wire to use 1 or 4 to hook a timeing light to and what is the timeing to be set at for a 74 z1-900 with a dyna-s and the rest all stock except for the header ?
- MFolks
- Thank you received: 540
09 Nov 2008 11:14 #246477
by MFolks
Replied by MFolks on topic timeing adjustment?
As you sit on the bike the left coil fires the #1 and #4 sparkplugs at the same time and the right coil fires #2 and #3. Sparkplugs are numbered from left to right sitting on the seat.
This type of ignition is considered a "wasted Spark" as it is fired during an exhaust stroke.
Does this answer your question?
- BigBlockT
09 Nov 2008 13:14 #246496
by BigBlockT
Replied by BigBlockT on topic timeing adjustment?
you helped with 1/2 of the question now what should the timeing be set at (what degree)?
- Thank you received: 2098
09 Nov 2008 14:22 #246501
by Patton
Replied by Patton on topic timeing adjustment?
In January 1994 the advancer changed to 20 degrees BTDC @ 1500 rpm from the previous 5 degrees.
Early advancer. Note close distance between F and T marks.
09 Nov 2008 14:25 #246502
by Patton
Later advancer. Note further distance between F and T marks.
Why not just set timing at idle rpm by aligning the F mark with permanent timing mark on engine case?
Good Luck!
Good Luck!
09 Nov 2008 14:55 - 09 Nov 2008 15:17 #246506
by Patton
Info from Z1E website:
If you have a 73 Z1 or an early 74 Z1A, we may need to supply a different crank rotor. Up through engine number Z1F-32817 kawasaki installed a 5/40 degree mechanical advancer (normal fire mark is 5 degrees then advancing to 40 degrees). If you have one of these on your engine, please enter a note in the special instructions to replace the standard rotor (3 rotor) in the Dyna-S with one special for these early bikes (3A rotor).)
Interpreted to mean that different rotors are needed for using a Dyna-S, depending on which advancer is fitted.
From your post, I am wondering if maybe the wrong Dyna-S rotor is fitted.
Sorry, I don't know how to visually tell the difference between the two separate Dyna-S rotors, or whether a Dyna-S rotor/advancer "misfit" may be finessed by simply re-setting the timing at idle rpm (thinking probably not, as it would also change the higher rpm advance from the desired 40 degrees BTDC.)
But am thinking the later advancer would be a direct swap replacement, as an option for using the "standard" Dyna-S rotor.
Good Luck!
Good Luck!
Last edit: 09 Nov 2008 15:17 by Patton.
