ART pistons
  • keith1
  • keith1's Avatar Topic Author
ART pistons
08 Nov 2008 18:15
#246389
are these stock pistons?...everything i have seen says
they might be....i was just wondering as there is no dicernable ridge at top of cylinder walls ...just wondering if this motor has been freshened before..
  • PLUMMEN
  • PLUMMEN's Avatar
Re: ART pistons
08 Nov 2008 18:31
#246391
probably origional pistons or kaw pistons used for a 1st overbore to clean up.ive seen lots of motors with no ridge,depends on how often oil was changed and type of oil used.ived seen a smalblock chevy that was run with synthetic oil from day one that had close to 300,000 on it that still showed crosshatch in cylinder walls B) what does the bore measure out at?;)
  • keith1
Re: ART pistons
08 Nov 2008 18:44
#246397
i did a quickie with a pos tape measure and it looks like 70 mm...stock i suppose...
  • kpier998
  • kpier998's Avatar
Re: ART pistons
08 Nov 2008 19:23
#246399
The 1100 pistons I have on a shelf are stock and say ART. Can post a pic if interested, but it would be Monday before I would be able to.
Kirk P
  • keith1
Re: ART pistons
08 Nov 2008 19:28
#246400
Kirk P
thats o k...i was just wonderin if stock ones had art imprinted on them...i guess they do....thanks again....
  • timebomb33
  • timebomb33's Avatar
Re: ART pistons
08 Nov 2008 21:28
#246402
most stock type cast japanese pistons are marked with those letters it is the manufacters mark,that company manufacters for all the o.e companies. i used to know the name of theoutfit but i'm getting older and there is only so much room in my head for usless trivia. maybe some one else can help.
I THINK MY POWERBAND BROKE
  • fixer5000
  • fixer5000's Avatar
Re: ART pistons
09 Nov 2008 01:07
#246427
theyre also oem in suzuki snowmobiles engines on arctic cats
www.art-piston.com.tw/
1978 kz650b pretty much stock
massachusetts
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
Re: ART pistons
09 Nov 2008 12:16
#246489
Art not only made OEM stock pistons, but aftermarket higher compression cast pistons. Back in the 70's they were one of the available performance options for the Z1's - compression around 10.5:1.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
