1075 12:1 kit
- iroc355
08 Nov 2008 12:00 #246328
by iroc355
1075 12:1 kit was created by iroc355
hey, im building up my drag bike thios winter, im looking at going with a 1075 12:1 kit from APE. Just wondering if anyone has had any experience with this kit at all and wut your thoughts are.
any suggestions as far as a different route to go with? this is going into a 1000 block.
ill be running it in a 76 kz900 frame, kz 400 forks, 4" stretched factory swingarm, 3.5" akront rear wheel with 5.5" slick, kz400 front wheel, sidewinder pipe, dyna ignition and coils and 2 step, fuel cell backbone, air shifter.
ill have the head done by fast by gast, and trans undercut.
- timebomb33
- Thank you received: 10
10 Nov 2008 09:30 #246630
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1075 12:1 kit
iroc i built that same combo for a friend of mine about 10 years ago other than pulling the head to change valve springs and changing clutch baskets a couple of times that engine always worked well it ran 9.80's down to 9.60's consistently. he finally broke the engine on the dyno after a cam change last year the crank let go. that engine had hundreds if not thousands of passes on it. so i'd say that was a good kit.
- iroc355
10 Nov 2008 14:40 - 10 Nov 2008 15:00 #246668
by iroc355
Replied by iroc355 on topic 1075 12:1 kit
thanks timebomb, kinda shocking on the times he was running, quite impressive!
im looking forward as to wut i can do!
what kinda chassis did he have it set up in?
Last edit: 10 Nov 2008 15:00 by iroc355.
- timebomb33
10 Nov 2008 19:10 #246730
by timebomb33
it was in a converted 78 1000 a frame the only thing left from the origanal frame was the cradle.he won the divison 6 bracket finals with that combo and went to pomona to run for the national bracket championship with that bike he blew [to much boozing] but the bike worked awesome every year it seemed to go quicker than it had the year before he has never been able to match it since.
