Engine temps?
- twowheeledterror
Engine temps?
17 Feb 2006 23:10
Ballpark here. What would be a high average for engine running temps max?
- steell
Re: Engine temps?
17 Feb 2006 23:37
Where are you measuring the temp?
Oil temp or cylinder head temp?
IIRC, oil temp should not exceed 230F and cylinder head temp somewhere around 400F, I'd have to look them up to be sure as it's been awhile.
- twowheeledterror
Re: Engine temps?
18 Feb 2006 09:11
steell wrote:
I shoulda mentioned that.
I'm trying to find the plastic to use for the window on the see thru clutch cover, and I need to get something that has a higher constant temp capability, and a much higher breakdown capability.
230 would work perfecty. The stuff I am looking at doesn't start to have breakdown till 300*, and can have a constant temp of up to 270* without a problem.
I'll be adding an oil cooler to the bike obviosly with the big bore kit, so I should be able to keep it below those temps.
- CTSZ1
Re: Engine temps?
18 Feb 2006 15:21
Don't know which bike you are looking for the window for but AmericanClassix.com sells one to fit a Z1. Might fit your application. I think it sells for about $20.00.
David
David
- BRGMGBGT
Re: Engine temps?
18 Feb 2006 16:41
You have probably figured this in, but, watch the expansion differences between plastic and aluminum. Depending on how you mount the window it could cause a sealing problem.
What plastic are you looking at?
- twowheeledterror
Re: Engine temps?
18 Feb 2006 18:33
BRGMGBGT wrote:
Polycarbonate/lexan.
I was planning on attaching it with a combination of bolts and a gasket in the inside to stop leakage.
- twowheeledterror
Re: Engine temps?
18 Feb 2006 18:33
CTSZ1 wrote:
No, it's closer to $250.00.
I'm making my own see thru cover.
David
- 77KZ650
Re: Engine temps?
18 Feb 2006 20:03
Make sure to post pics of it! maybe even the build in progress pics, if it looks easy, and as cool as I think it will, I might try to make one if yours works out.
07 MDP Rookie of the Year
- twowheeledterror
Re: Engine temps?
18 Feb 2006 20:53
77KZ650 wrote:
Do you have access to machining equiptment? Mills, CNC, etc? You'll need to to make it.
Post edited by: twowheeledterror, at: 2006/02/18 23:54
- 77KZ650
Re: Engine temps?
19 Feb 2006 09:19
twowheeledterror wrote:
Not really....
I guess this is too precise for the basic shop tools eh?
77KZ650 wrote:Make sure to post pics of it! maybe even the build in progress pics, if it looks easy, and as cool as I think it will, I might try to make one if yours works out.
<br><br>Post edited by: twowheeledterror, at: 2006/02/18 23:54
Not really....
- twowheeledterror
Re: Engine temps?
19 Feb 2006 10:01
77KZ650 wrote:
Not too precise, but it'd be damn near im possible to make a round hole perfectly, and would take you forever. If it's something you want to do I could make you one once I move and get my garage set up.
twowheeledterror wrote:77KZ650 wrote:Make sure to post pics of it! maybe even the build in progress pics, if it looks easy, and as cool as I think it will, I might try to make one if yours works out.
Not really....I guess this is too precise for the basic shop tools eh?
- 77KZ650
Re: Engine temps?
19 Feb 2006 20:35
I would like to build it myself, but if it proves to be too much to tackle with my stuff, I may give you a shout. Are you moving anywhere close to central N.B.?thanks
Scott
Scott
