650 kicker
- EarthShaker
07 Nov 2008 20:51 #246196
by EarthShaker
First to fight, Last to leave
1976 kz650 runs but still needs finishing
1976 kz650 basket case project
650 kicker was created by EarthShaker
Thinking about make my 650 in to a kicker only What will I need to change? this is the first time I thought about this. please help. thanks
- timebomb33
- Thank you received: 10
08 Nov 2008 02:21 #246222
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 650 kicker
i'm pretty sure if you pull the starter and block the starter drive hole with a starter block off plug that ape sells and remove the starter cable running from the solinoid to the starter but leave the one going from battery to the solinoid as that is your main power supply for the bike.i take of all my starters on all my 900 and 1000s except for my j. if you get ambitous later than you can take the starter drive out of the cover but don't worry about it as it can't go anywhere.
