Cam question K410 vs K435
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- PLUMMEN
- Thank you received: 104
- timebomb33
I THINK MY POWERBAND BROKE
- Exitpupil
- timebomb33
- davel
It's a good question. Maybe Jay will give his reasoning.I do not understand why .025 more lift makes a cam "dragrace only" in "smaller motors". The duration is the same. Does more lift kill flow on bottom end? Or are larger ports required to utilize the extra .025" lift, thus less bottom end?
Are you still looking for more performance out of your 1075? I'd like to know some dyno results and 1/4 mile times from your setup with the 410s.
- larrycavan
- Visitor
Look at TDC OVERLAP lifts and lobe centers.
Lift & Duration numbers alone won't give you an accurate picture of the lobe profile. K435 will make more top end power. You want airflow to take advantage of that cam. Go with the K410 on the street in a small motor. K4354 will pull like a prick up top though.
- Exitpupil
- larrycavan
- Visitor
APE offers the K435 on their 1200 street package and the K410 for the 1075 street package. Larry makes an interesting point about different profiles even with same duration. One thing I was wondering was if you had a ported head with stock valves would the extra lift give more top end power while keeping the bottom end torque?
Web has a similar cam, their 109 grind. In stock bore, 84 GPz 1100, with fly cut pistons [compression actually reduced] 33mm Keihin CRS carbs and 95CFM @10" head with stock valves, Murray Pipe, 4000 RPM was where the thing would start to work well. That was on 106 lobe centers.
So just how low you consider bottom end is the key thing. Below 4000 RPM you could not wack the slides open. The engine required a progressive throttle hand but rewarded the effort with pretty good response. Those carbs were w/o any type of accel pump.
Compression and capacity is the name of the game for keeping bottom end torque with cams designed for high rpm. APE knows what they're talking about with the kits they put together. They're designed as a package of components that compliment each other well.
Take a set of drop in .365 lift cams. Spread the centers to 114*, you'll be amazed at how much top end you get out of them.....
- APE Jay
- Banned
- Thank you received: 58
We have customers that do 1075s with tricked out heads and they run 435s.
Jay
- Exitpupil
