- Thank you received: 2
cam chain manuevering
- keith1
02 Nov 2008 11:46 #245161
by keith1
cam chain manuevering was created by keith1
i started stripping bike and i am at the point of taking cams out...i have them in the right position as per the manual...i just have to pull tensioner and tach drive....when i get to the point of actally pulling head are there any tricks
for handling chain? book says to hang it up...thats all well and good but at some point i m going to have to pass it through the head....anyone have any tips? tricks? is this actally not as tricky as i think its gonna be?
first time delving this deep so dont know what to expect....thanks keith
- timebomb33
- Thank you received: 10
02 Nov 2008 12:21 #245164
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic cam chain manuevering
no big problem just let it go you can fish it out later the only reason you would have to worry about crank position is if you were reinstalling the head right away if your stripping it down don't worry about it.
- jordan
- Thank you received: 5
02 Nov 2008 12:28 #245169
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic cam chain manuevering
well, there are probably multiple ways to go about this but here is how i did it. while the head is still on its easy to just set a pencil, screwdriver, or something like that through the chain across the head where the cams sit to keep the chain from dropping down into the cases. then you can slowly lift the cases off of the studs, You can lift the head quite a ways up before the chain gets tight on the object you have keeping the chain from falling. You now have quite a gap between the cylinders and head. Its easy to grab a ziptie and now ziptie the cam chain to a stud, remove your object and then pull off the head. Then just repeat the same process again when removing the cylinders. Also, dont freak if you drop the chain down in the cases. I did this and you will find a way to reach down and grab onto it and then you just have to wiggle it around until you get it back on the crank cam chain sprocket.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- keith1
02 Nov 2008 14:20 #245199
by keith1
Replied by keith1 on topic cam chain manuevering
thanks guys.........
- bountyhunter
- Thank you received: 337
02 Nov 2008 14:33 - 02 Nov 2008 14:34 #245203
by bountyhunter
Replied by bountyhunter on topic cam chain manuevering
jordan wrote:
I use a paint stir stick. It's thin, flat and level so you can slide it in easily and it stays put.well, there are probably multiple ways to go about this but here is how i did it. while the head is still on its easy to just set a pencil, screwdriver, or something like that through the chain across the head
Last edit: 02 Nov 2008 14:34 by bountyhunter.
- School Teacher
02 Nov 2008 20:06 #245278
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic cam chain manuevering
i usually make my buddy help me. he he
1980 kz1000G1
- Old Man Rock
- Thank you received: 225
03 Nov 2008 07:24 - 03 Nov 2008 07:25 #245338
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic cam chain manuevering
I use a piece of coat hanger "C" bent and hang it on the frame straight up. Quick and easy connect/disconnect for feed through the cylinder, head whatever. And being small in diameter, slides through most openings...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Nov 2008 07:25 by Old Man Rock.
