Preferred clearances?
- sbulla
- 1980 KZ1000 LTD
31 Oct 2008 19:53 #244881
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Preferred clearances? was created by sbulla
Got my cam cap bolt hole repaired and took my measurements tonight. One gap was smaller than my thinnest feeler gage but, the bucket will spin so there's some clearance.
Is there a preferred clearance for these or is anywhere in the .05 to .15mm spec OK?
What would you guys recommend with these measurements...
1980 KZ1000LTD B4
1 intake-.051mm
2 intake-.102mm
3 intake-.102mm
4 intake-(less than) .038mm
1 exhaust-.127mm
2 exhaust-.076mm
3 exhaust-.076mm
4 exhaust-.127mm
Sonny
1980 KZ1000LTD B4
1 intake-.051mm
2 intake-.102mm
3 intake-.102mm
1 exhaust-.127mm
2 exhaust-.076mm
3 exhaust-.076mm
4 exhaust-.127mm
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- timebomb33
- Thank you received: 10
31 Oct 2008 21:20 - 31 Oct 2008 23:24 #244887
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Preferred clearances?
sbulla i would go down 2 sizes on no.4 and 1 size on no.1 that should get you pretty close to the middle of the range which is where you want to be and 1 size on both 2 and 3 on the exhaust. i know they are both in spec. but it is always better to run the exhaust a bit on the loose side on street motors because of carbon build-ups on the valve seats and since you are already in there it is easy to do now.on my own motors i normally run .004" on the intake and.006" on the exhaust but that is the way i've been doing it for years. the stock kawi clearances close enough for the street. good luck and don't hesitate to ask me if you need more assistance. by the way nice to hear that the operation was a success doctor. some times doing heli coils in a head that is attached to a motor can be tense. i learned some thing with this thou ill be trying that foil over the head to keep the chips down for sure never thought to do it before thats one of those things that you hear and go doooooh.
Last edit: 31 Oct 2008 23:24 by timebomb33.
- bountyhunter
- Thank you received: 337
31 Oct 2008 22:10 - 31 Oct 2008 22:17 #244898
by bountyhunter
Replied by bountyhunter on topic Preferred clearances?
The clearance specs for my 750 are 0.5 - 1.0 mm (.002" - .004" ). I set them at .003" - .005". A shade wide hurts nothing, too tight and the valve seat is toast.
Valves usually get tighter over time after a valve job, so set to the upper limit of the range if you have a shim to get it there.
BTW: I agree exhaust valves are safer if run a shade wider than intake. They get hotter and expand more linearly, so (IMHO) you don't want to set them at the lower limit of the range.
As listed above. .004" intake and .006" exhaust is used for a whole lot of engines and gives a bit more headroom. Going a shade wide may give up a tiny bit of peak HP by altering the cam timing and lift very slightly, but you will never feel the difference.
Last edit: 31 Oct 2008 22:17 by bountyhunter.
- sbulla
- 1980 KZ1000 LTD
01 Nov 2008 08:52 #244928
by sbulla
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
Replied by sbulla on topic Preferred clearances?
OK, just to double check my math...
I checked all the shims for size and have them listed below along with the ones I need to order. Take a look and reassure me I'm on the right path. I figure I only need one 280 and 2 270's.
Thanks for the replies,
Sonny
1980 KZ1000LTD B4
1 intake-.051mm-275-need 270
2 intake-.102mm-275
3 intake-.102mm-280
4 intake-(less than) .038mm-280-need 270
1 exhaust-.127mm-270
2 exhaust-.076mm-285-need 280
3 exhaust-.076mm-285-need 280
4 exhaust-.127mm-280
Sonny
1980 KZ1000LTD B4
2 intake-.102mm-275
3 intake-.102mm-280
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- RonKZ650
- Thank you received: 240
01 Nov 2008 09:49 #244939
by RonKZ650
Replied by RonKZ650 on topic Preferred clearances?
Looks like you've got it all figured correctly
- timebomb33
02 Nov 2008 21:02 #245293
by timebomb33
sorry i didn't get back on here until now but it look's like you nailed it. the first time you do anything it looks tougher then it really is.
