- Thank you received: 225
Exhaust Half Collars @ Z1?
- Old Man Rock
I can pick these up at Red line but since I need to order some other stuff at Z1, was wondering if they offered a kit of these as well (or individually) but I can't seem to find at Z1...
Anyone know?
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
Hey all, & Jeff...
Anyone know?
Thanks,
OMR
mine came with my pipe...i thought z-1 had them, but i dont see them....i guess jeff will chime in..good luck.....keith
- Jeff.Saunders
The problem with V&H (and other brand aftermarket pipes) is the lip on the header pipe that sits in the exhaust port is far thinner than on the factory pipes. Because of this, V&H and others provide slightly longer split collars - usually about 1/8" longer. If you use the factory collars with V&H pipes, the exhaust flange will bottom against the head before totally sealing the copper exhaust gasket into the port.
We can get them in, our price is around $4.60 each
www.z1enterprises.com
Z1 Ent on Facebook,
- Old Man Rock
Ok, I have the Kerker 4 to 1 Megaphone. Jeff or anyone else know what I will need in half collars with the Z1 Exhaust Flanges?
Exhaust Flanges KZ1000 KZ1100 ZN1100
18069-1015
OEM: 18069-1015
Aluminum Exhaust Flanges sold individually 4 needed for set. Originally fitted on the 81 and up Kawasaki KZ1000's, these also fit early Kawasaki KZ1000 77-80. Genuine Kawasaki Motorcycle part
Thanks,
Omr
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Jeff.Saunders
Original Kawasaki pipes, the lip thickness is around 3mm. On V&H, they are around 1.5mm thick. I remember on some of the Kerker pipes them being decent thickness, but with Kerker now being owned by Supertrapp they changed the manufacturing processes.
If you ever run into a situation where the exhaust flange bottoms out on the head before totally sealing the exhaust gasket, there are thicker exhaust gaskets available.
www.z1enterprises.com/detail.aspx?ID=1602 These are about 2mm thicker than stock exhaust gaskets and they overcome the lip thinness issue. You don't want to routinely go with them unless you do have a problem - otherwise you can't get the nut started on the stud...
Z1 Ent on Facebook,
- Old Man Rock
How much is lost in doubling up the gaskets if required?
No wonder this bike didn't have collars when I got it... Other than being a 30 year old POS that is... Really crappy after market pipes.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
SKU: 92027-170 INSERT,EXHAUST PIPE
With this in mind, for those that have installed Kerker 4-1 Meg series pipes on their bikes, did you guys use the collars, thicker/double copper gaskets or something else?
Glad I looked into this, maybe just saved myself $42.:laugh:
Thanks all,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Tony
- Thank you received: 13
(link to thread)
I ordered a set of oem ones.
- Tony
- Old Man Rock
Seems that is what Redline is offering... $42 for the set...
Thanks all,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
- Old Man Rock
Then throw into the mix my head (KZ head damn it :laugh:) has been shipped to Larry C so I can't even do any measurements. Poor OMR. :dry: :blink:
Same time, seems the OEM is what everyone had to use with the KZ1000 exhaust flanges. I'll probably just wait till I get the head back, installed and then test for measurements.
Thanks bud!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
