KZ650 Cam Chain Roller Question
- 77_650B1
28 Oct 2008 19:27 #244391
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
KZ650 Cam Chain Roller Question was created by 77_650B1
So I took apart my engine, and the shafts for my cam chain rollers dont have those rubber rectangular deals on the end, they're just round shafts. Whats my deal? Is it because it's Canadian?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- RonKZ650
- Thank you received: 240
28 Oct 2008 19:33 #244394
by RonKZ650
Replied by RonKZ650 on topic KZ650 Cam Chain Roller Question
77s didn't have them at least at the first of the run. 78s all had them. Some 77s may have them later in the production year. I'm not exactly sure when they were added, but it was in that time frame. My 77s don't have them either. They were added to quiet the camchain area down. I can't tell any difference myself and since the rubbers turn to plastic whithin 1000 miles of install, I think the advantage is nil.
- 77_650B1
28 Oct 2008 19:37 #244395
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic KZ650 Cam Chain Roller Question
Cool, I thought it might be something like that. And its funny because they say to check them for wear. Maybe the ones with the rubbers wear out easier, mine aren't worn appreciably. My internals are in surprisingly good shape actually.
Now I just gotta get everything straightened out for 810cc!!
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
29 Oct 2008 07:38 #244458
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic KZ650 Cam Chain Roller Question
There were a whole bunch of changes made to the cam chain idlers and tensioner from engine serial number 054600 onwards....so the rubber blocks may have been one of those changes. They were probably added in an effort to reduce the chain noise transmitted to/through the block and head. God forbid that the customer would actually be able to hear what was happening in the engine..... :laugh:
- RonKZ650
29 Oct 2008 10:24 #244479
by RonKZ650
This change was made at engine # 019150 or about 1/2 way through 77 production
