Dead cylinder!
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
ThanksB)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- Old Man Rock
- Thank you received: 225
So assuming you have completed the above correctly, is it possible that the bluing is not as noticeable?
Is the bluing on your exhaust header from when you got this bike or after the work completed on a shiny header, this is the only cylinder exhaust that is bluing?
If all checks out, I'd go with #3 carb not tuned correctly, too lean or different jet or etc...
Possible something else but I'd check that for sure.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- BSKZ650
- Thank you received: 14
also have you checked the valves
77 ltd1000, current rider
76 kz900, just waiting
- rammy
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Crank until the guage stops rising, theres your compression. Should only take bout 3-4 turn overs to max.
The gauge should stay exactly where it stops. If it starts to fall, you have a pressure leak. Add couple teaspoons oil to the cylinder and do it again. If the pressure rises signifcantly, then rings are pretty bad. If no change, then most likely valve not seating/closing properly.
Properly done "leak down" test after that can reveal specifics...
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- thadley55
Well I have done the valve adjustment. I warmed up the engine and checked the compression like I was instructed. My #'s are as follows;
#1-80
#2-70
#3-70
#4-80
I know these #'s are low but the good news is they are consistent! However that doesn't answer my question about the dead cylinder. I was rechecking the timing and when I put the signal picker'-upper' on the #3 plug wire I had to shake it to get a signal. Now, I know that those sgnal readers are touchy and this may belong in another thread but, is it possible for one coil to be half bad?
Thanks for all your help!!
BTW, Is it really bad to have too much valve clearance?
- bountyhunter
- Thank you received: 337
If those are correct, the engine is hosed.Hey guys!
#1-80
#2-70
#3-70
#4-80
thadley55 wrote:
The valves will get "clicky" if the clearance is a bit too wide (like a few thousandths) but won't affect performance much.BTW, Is it really bad to have too much valve clearance?
- wiredgeorge
If the compression readings shoot up, this will indicate the rings are not sealing as they should. If compression doesn't shoot up a bunch, this indicates the valves are the issue. This points back to valve clearance issues.
With compression like you have noted ~70 to 80 psi, the bike will likely start but performance will be poor.
You will then move to ignition issues. First thing to do is to swap the #3 plug wire with the #2 and see if the problem stays on the third cylinder. If it moves, you have either a wire, cap or spark plug problem on #2. Quit messing with the gizmo you are using... try this method. if the problem stays on the #3 cylinder, then the carburetor is the probable issue.
When the bike starts, it may not fire at idle but if you take it on the road for a bit, stop and spray the pipes with a squirt bottle filled with water. Water will vaporize if the cylinder is firing but pop and spit off the pipe if it isn't. Pinpointing whether the cylinder is firing at higher speeds is important to get you to the part of the carburetor you need to focus on if you need to either clean or disassemble.
I strongly suggest you approach the problem and go through the steps as I suggest. If you don't you are essentially jumping around and chasing rabbit trails and really not proving anything conclusively.
- thadley55
ThanksB)
- Old Man Rock
....:blink:complete rebuild
Sure but you might possibly only need a $200 valve job....
Probably best to follow everything that has been posted back at you before totally re-building your motor.
As written, if your timing is off (CAM lobes), valves will not seal properly thus you will measure low compression.
Same time, you have the time and funds... build away!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
- thadley55
